Solved Problem does not hear anything with calls via gsm gateway
Discussion in '3CX Phone System - General' started by rsamaniego, Aug 16, 2017.
  1. rsamaniego
    Aug 11, 2017
    5
    hI, I deployed the 3CX V15.5.5 on a machine with Windows 10 with firewall and antivirus disabled.
    I have provisioned several AAstra 6730i phones and calls between them are set and heard perfectly.
    I configured a topex gsm gateway with 2 sim by following these steps:
    Https://www.3cx.com/blog/docs/topex-gsm-gateway/
    It turns out that calls through the gateway are set but nothing is heard (they are both on the Lan)
    The firewall test gives me the following:
    •resolving ‘stun-eu.3cx.com’… done
    •resolving ‘stun2.3cx.com’… done
    •resolving ‘stun3.3cx.com’… done
    •resolving ‘sip-alg-detector.3cx.com’… done
    •testing 3CX SIP Server… failed (How to resolve?)◦stopping service… done
    ◦detecting SIP ALG… not detected
    ◦testing port 5060… full cone test failed (How to resolve?)
    ◦starting service… done
    •testing 3CX Tunneling Proxy… failed (How to resolve?)◦stopping service… done
    ◦testing port 5090… full cone test failed (How to resolve?)
    •testing 3CX Media Server… canceled◦stopping service… done
    ◦testing ports [9000..9255]… canceled◾testing port 9000… full cone test failed (How to resolve?)
    ◾testing port 9001… full cone test failed (How to resolve?)
    ◾testing port 9002… full cone test failed (How to resolve?)
    ◾testing port 9003… full cone test failed (How to resolve?)
    ◾testing port 9004… full cone test failed (How to resolve?)
    ◾testing port 9005… full cone test failed (How to resolve?)
    ◾testing port 9006… full cone test failed (How to resolve?)
    ◾testing port 9007… full cone test failed (How to resolve?)
    ◾testing port 9008… full cone test failed (How to resolve?)
    ◾testing port 9009… full cone test failed (How to resolve?)
    ◾testing port 9010… full cone test failed (How to resolve?)
    ◾testing port 9011… full cone test failed (How to resolve?)
    ◾testing port 9012… full cone test failed (How to resolve?)
    ◾testing port 9013… full cone test failed (How to resolve?)
    ◾testing port 9014… full cone test failed (How to resolve?)
    ◾testing port 9015… full cone test failed (How to resolve?)
    ◾testing port 9016… full cone test failed (How to resolve?)
    ◾testing port 9017… full cone test failed (How to resolve?)
    ◾testing port 9018… full cone test failed (How to resolve?)
    ◾testing port 9019… full cone test failed (How to resolve?)
    ◾testing port 9020… full cone test failed (How to resolve?)
    ◾testing port 9021… full cone test failed (How to resolve?)
    ◾testing port 9022… full cone test failed (How to resolve?)
    THANKS
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
  3. rsamaniego
    Aug 11, 2017
    5
    Why the firewall? The communication does not go through the firewall because the gsm gateway and the 3cx server are on the same network (Lan) only firewall of windows and it´s disabled.
    Anyway I have reviewed the configuration of the firewall of the wan and is as follows
    Ipfija <-> ip_lan_3cx
    443 TCP
    80 TCP
    5090 UDP and TCP
    5060 UDP and TCP
    5061 TCP
    5000-5001 TCP
    9000-9500 UDP
    And IOS and Android devices are well provisioned.
    thanks.
  4. rsamaniego
    Aug 11, 2017
    5
    Solved, the server 3cx had two fixed ips of different lan and the firewall blocked the communication.
