problem entering smtp address
Discussion in '3CX Phone System - General' started by wil, Sep 12, 2007.
  1. wil
    wil
    Sep 12, 2007
    I did a quick search and was unable to find anything here.
    Basically, I am evaluating 3cx in a sandbox enviroment, during setup I mistyped the SMTP server address as internal1r
    It installed fine and I went to the administration page and tried typing internal1
    Every time I press enter or ok, smtp server just turns red and I get a popup saying that the smtp server is invalid
    I have tried various other things such as mail.internal1 mail.internal1:25 (both invalid, but I was just testing), internal1:25 (which should work), however I could not get any combination to work!
    Just hoping someone can help me!
  2. tab
    tab
    Aug 10, 2007
    85
    hi,
    Does anything else application apply this smtp server?
    tab
  3. wil
    wil
    Sep 12, 2007
    The address internal1 is the valid SMTP server that everything else uses fine..
    .. from the same machine "telnet internal1 25" connects and works just fine.
  4. tab
    tab
    Aug 10, 2007
    85
    You should try to apply simple static ip address.
    tab
  5. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Good thinking tab, going by IP is a good workaround.
    Going by FQDN internal1.contoso.com (if contoso.com was your domain) should also work too.
