Problem in connecting extension via vpn
Discussion in '3CX Phone System - General' started by rickburt, Nov 12, 2007.
  1. rickburt
    Nov 9, 2007
    Hello
    I have a problem with my extension in that when I try to ring either voice mail, an internal extension of voip provider I get a ringing tone but no audio when the call is answered.
    configuration is
    3cx phone system on a Windows 2003 SBS server on 192.168.0.10
    extension (either Grandstream 2000 or x-lite) on 192.168.24.6
    vpn link via Netgear 834 router.
    One thing I note is that the media server seems to be bound to the public IP address of the router that is local to it. Surely it should bind to the private address 192.168.0.10? I do not know where it's getting this public Ip address?
    I have enable and disabled the "extension is external", "bind to media server" and "supports re-invite" and the problem still occurs.
    Rick Burt
    The server log of a failed call is outlined below.
    08:01:46.296 MediaServerReporting::RTPReceiver [MS105000] Call(27) Ext.220: No RTP packets were received on 00000027@:remoteAddr=192.168.0.10:5004,extAddr=xxx.xxx.xxx.xxx:9060,localAddr=0.0.0.0:9060
    08:01:46.296 StratInOut::eek:nCancel [CM104009] Call(27): Call from Ext.220 to 333 has been terminated
    08:01:31.015 CallLegImpl::eek:nConnected [CM103001] Call(27): Created audio channel for Ext.220 (192.168.0.10:5004) with Media Server (212.159.70.171:9060)
    08:01:30.937 CallConf::eek:nIncoming [CM103002] Call(27): Incoming call from 220 (Ext.220) to sip:333@192.168.0.10
    08:01:18.203 ServRegs::eek:nAdd [CM113002] Registered: Ext.220
    08:01:17.734 ServRegs::eek:nRemoveAll [CM113004] Unregistered: Ext.220
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hi.
    What version and build is your 3CX?
    Take a look at this as well.
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/how-to-make-extension-in-any-where-of-the-internet-2193/
  3. rickburt
    Nov 9, 2007
    3cx Version
    The version I am using is "3CX Phone System v3.1.2434.0"
    Rick
  4. Mori
    Mori New Member
    Mar 23, 2007
    223
    Re: 3cx Version
    VPN is not supported yet.
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/3cx-phone-system-v4-0---alpha-version---available-2812/
    (anybody correct me if im wrong :p )
  5. alicic
    alicic New Member
    Oct 3, 2007
    119
    how vpn is not supported.
    It is, I register my X-Lite through VPN and use services of 3cx Phone system
  6. Mori
    Mori New Member
    Mar 23, 2007
    223
    Then im wrong. :)
    Just know that VPN will be available in v.4..
  7. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi rickburt,
    It seems you activated stun at your "Grandstream 2000 or x-lite". For all SIP clients under VPN connected to 3CX BOX or any IPPBX need not activate the STUN. Please check both of them if found enable of stun, try disable it.
