problem on incoming call ** SNOM PROBLEMS
Discussion in '3CX Phone System - General' started by lirees, Jan 3, 2011.
  1. lirees
    Mar 17, 2008
    5
    hi
    My 3CX sometimes has a strange behavior, when the call enter the operator answers but he hear a greeting message that i have record of the IVR, in the other cases the operator does not hear anything
    i have 3cx sp5 with snom 370 firmware 7.3.30 and 2 patton 4554 with firmware version 5.6
    thanks
    11,293
    361
    Re: problem on incoming call
    Unfortunately, intermittent troubles are the hardest to troubleshoot. You need to find some sort of a pattern to to failures, time of day, where the call is originating, who else is using an extension, etc.
    A 3CX log of a failing call might help, but, of course, when you can't readily duplicate the issue, it becomes very difficult.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    I would start troubleshooting snom phones - they are becoming very weak in performance.
    All the snoms in my test department have performance issues - slow in operation. Sometimes I wonder just what they are doing sending a couple of registrations and some blf. reboot the phone - see if you see an immediate difference.
