Problem SPA942 & Grandstream4104 work fine for while
Discussion in '3CX Phone System - General' started by DMistry, Feb 12, 2009.
  1. DMistry
    Feb 12, 2009
    I am using free version of 3CX. All setup working fine for while. Than can not make inbound or outbound call. When I make any internal call using softphone than after everything start to work . But its work for few minute and again everthing going down. Unless I make any internal call using softphone. Anyone please help me on this.
    Thank you.
  2. integrax
    Dec 9, 2008
    19
    Can you be more specific in your question please?
    When you say “everything going down” what exactly happen?
    Can you post a server activity log after everything going down?
  3. DMistry
    Feb 12, 2009
    Thank you for your reply. Everything going down mean I am not able to receive or dial any call from my SPA942 phone and other soft phone.Its start to work only when I make call from my soft phone that installed on same computer where 3CX phone system installed. And after few minute again same problem.
    2009/02/12 >>
    15:24:28.989|1634|.\3CXIvrService.cpp(892):IvrService, main(), Starting service, revision 7.0.3798.0
    15:24:28.989|0c7c|.\3CXIvrService.cpp(637):IvrService, MainServiceProc::Run(), Initializing php updater
    15:24:28.989|0c7c|.\3CXIvrService.cpp(646):IvrService, MainServiceProc::Run(), Writing global parameters to php ...
    15:24:28.989|0c7c|.\IVR_Api.cpp(631):IvrDll, Ivr_SetLog(), External log has been set for IVR dll
    15:24:28.989|0c7c|.\IVR_Api.cpp(311):IvrDll, IVRApi::Init(), Initializing, revision 7.0.3612.0
    15:24:29.004|0c7c|.\IVR_Api.cpp(172):IvrDll, IVRApi::LoadConfiguration(), Using config file 'C:\Program Files\3CX PhoneSystem\Bin\..\Data\Ivr\Cfg\3CXIvr.cfg'
    15:24:29.004|0c7c|.\IVR_Api.cpp(206):IvrDll, IVRApi::LoadConfiguration(), Default vxml document: 'http://localhost:5484/ivr_start.aspx'
    15:24:29.145|0c7c|.\3CXIvrService.cpp(728):IvrService, MainServiceProc::Run(), Service started
    15:24:29.145|0c50|.\SLAgent.cpp(230):IvrService, SLAgent::Run(), Reconnected to 127.0.0.1:5482 SL server
    15:24:37.535|0c50|.\PbxMedia\IVREngine.cpp(853):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[800][][]
    15:24:37.535|0c50|.\PbxMedia\IVREngine.cpp(869):IvrService, IVREngine::RegisterLines(), Registering SpeciaMenu:999
    15:24:38.488|0c50|.\PbxMedia\IVREngine.cpp(907):IvrService, IVREngine::RegisterLines(), Registering IVR:800
    15:24:38.488|0c50|.\PbxMedia\IVREngine.cpp(978):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    Thnka you very much
  4. DMistry
    Feb 12, 2009
    here
    Server Activity Log
    10:59:20.572 [CM504001]: Ext.109: new contact is registered. Contact(s): [sip:109@127.0.0.1:5070;rinstance=8e66710cd1449bf8/109]
    10:59:20.041 [CM504002]: Ext.109: a contact is unregistered. Contact(s): []
    10:58:49.167 [MS105000] C:47.1: No RTP packets were received:remoteAddr=127.0.0.1:42016,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7004
    10:58:48.152 [CM503008]: Call(47): Call is terminated
    10:58:48.058 [CM503020]: Call(47): ACK is not received
    10:58:45.433 [MS105000] C:46.1: No RTP packets were received:remoteAddr=127.0.0.1:42014,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7000
    10:58:15.841 [CM503007]: Call(47): Device joined: sip:10002@192.168.1.103:5064
    10:58:15.825 [CM503007]: Call(47): Device joined: sip:109@127.0.0.1:5070;rinstance=4e3cca1daf969ea5
    10:58:15.825 [CM505002]: Gateway:[Cavalier Phone Netowrk] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:10) 1.0.1.8] Transport: [sip:192.168.1.100:5060]
    10:58:15.809 [CM503002]: Call(47): Alerting sip:10002@192.168.1.103:5064
    10:58:13.841 [CM504008]: Fax Service: registered as sip:888@192.168.1.100:5060 with contact sip:888@192.168.1.100:5100;user=phone
    10:58:13.825 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:999@127.0.0.1:40600;rinstance=5efe8e0f65d896f6/999]
    10:58:13.778 [CM504001]: Ext.800: new contact is registered. Contact(s): [sip:800@127.0.0.1:40600;rinstance=b0fe7375b827225d/800]
    10:58:13.294 [CM503008]: Call(46): Call is terminated
    10:58:13.278 [CM504002]: Ext.800: a contact is unregistered. Contact(s): []
    10:58:13.263 [CM504002]: Ext.999: a contact is unregistered. Contact(s): []
    10:58:13.185 [MS101004] STUN server address 'stun2.3cx.com:3478' is incorrect
    10:57:58.935 [MS101004] STUN server address 'stun.3cx.com:3478' is incorrect
    10:57:40.155 [CM503003]: Call(47): Call to sip:2766666614@192.168.1.103:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.1.103:5060
    10:57:40.155 [CM503008]: Call(46): Call is terminated
    10:57:40.155 [CM503020]: Call(46): ACK is not received
    10:57:40.061 [MS101004] STUN server address 'stun2.3cx.com:3478' is incorrect
    10:57:25.812 [MS101004] STUN server address 'stun.3cx.com:3478' is incorrect
    10:57:07.032 [CM503003]: Call(47): Call to sip:2766666614@192.168.1.103:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.1.103:5060
    10:57:07.016 [CM503007]: Call(46): Device joined: sip:10001@192.168.1.103:5062
    10:57:06.985 [CM503007]: Call(46): Device joined: sip:109@127.0.0.1:5070;rinstance=4e3cca1daf969ea5
    10:57:06.985 [CM505002]: Gateway:[Cavalier Phone Netowrk] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:9) 1.0.1.8] Transport: [sip:192.168.1.100:5060]
    10:57:06.969 [CM503002]: Call(46): Alerting sip:10001@192.168.1.103:5062
    10:57:06.891 [MS101004] STUN server address 'stun2.3cx.com:3478' is incorrect
    10:56:52.642 [MS101004] STUN server address 'stun.3cx.com:3478' is incorrect
    10:56:33.877 [CM503004]: Call(47): Calling: PSTNline:2766666614@(Ln.10000@Cavalier Phone Netowrk)@[Dev:sip:10000@192.168.1.103:5060, Dev:sip:10001@192.168.1.103:5062, Dev:sip:10002@192.168.1.103:5064, Dev:sip:10003@192.168.1.103:5066]
    10:56:33.846 [CM503010]: Making route(s) to <sip:2766666614@192.168.1.100:5060>
    10:56:33.846 [CM505001]: Ext.109: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4526.0] Transport: [sip:192.168.1.100:5060]
    10:56:33.830 [CM503001]: Call(47): Incoming call from Ext.109 to <sip:2766666614@192.168.1.100:5060>
    10:56:33.815 [MS101004] STUN server address 'stun2.3cx.com:3478' is incorrect
    10:56:19.565 [MS101004] STUN server address 'stun.3cx.com:3478' is incorrect
    10:56:00.801 [MS101004] STUN server address 'stun2.3cx.com:3478' is incorrect
    10:55:46.536 [MS101004] STUN server address 'stun.3cx.com:3478' is incorrect
    10:55:27.834 [CM503003]: Call(46): Call to sip:2766666614@192.168.1.103:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.1.103:5060
    10:55:27.756 [MS101004] STUN server address 'stun2.3cx.com:3478' is incorrect
    10:55:13.506 [MS101004] STUN server address 'stun.3cx.com:3478' is incorrect
    10:54:54.726 [CM503004]: Call(46): Calling: PSTNline:2766666614@(Ln.10000@Cavalier Phone Netowrk)@[Dev:sip:10000@192.168.1.103:5060, Dev:sip:10001@192.168.1.103:5062, Dev:sip:10002@192.168.1.103:5064, Dev:sip:10003@192.168.1.103:5066]
    10:54:54.710 [CM503010]: Making route(s) to <sip:2766666614@192.168.1.100:5060>
    10:54:54.710 [CM505001]: Ext.109: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4526.0] Transport: [sip:192.168.1.100:5060]
    10:54:54.695 [CM503001]: Call(46): Incoming call from Ext.109 to <sip:2766666614@192.168.1.100:5060>
    10:54:54.679 [MS101004] STUN server address 'stun2.3cx.com:3478' is incorrect
    10:54:40.430 [MS101004] STUN server address 'stun.3cx.com:3478' is incorrect
    10:52:32.093 [CM504008]: Fax Service: registered as sip:888@192.168.1.100:5060 with contact sip:888@192.168.1.100:5100;user=phone
    10:52:24.531 [CM504001]: Ext.800: new contact is registered. Contact(s): [sip:800@127.0.0.1:40600;rinstance=b0fe7375b827225d/800]
    10:52:24.515 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:999@127.0.0.1:40600;rinstance=5efe8e0f65d896f6/999]
    10:52:19.828 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=bf2cd442e4389225/*1]
    10:52:19.812 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=3f6f4c2b11349b73/*0]
    10:52:12.594 [CM112000] Media Server is connected
    10:52:12.203 [CM504002]: Ext.800: a contact is unregistered. Contact(s): []
    10:52:12.156 [CM504002]: Ext.999: a contact is unregistered. Contact(s): []
    10:52:11.625 [CM504002]: Ext.800: a contact is unregistered. Contact(s): []
    10:52:11.609 [CM504002]: Ext.999: a contact is unregistered. Contact(s): []
    10:52:07.735 [CM504002]: Ext.*1: a contact is unregistered. Contact(s): []
    10:52:07.672 [CM504002]: Ext.*0: a contact is unregistered. Contact(s): []
    10:52:07.188 [CM504002]: Ext.*1: a contact is unregistered. Contact(s): []
    10:52:07.172 [CM504002]: Ext.*0: a contact is unregistered. Contact(s): []
    10:52:06.438 *** Server shut down ***
    10:52:06.438 *** Exit Listen ***
    10:52:06.438 *** Server started ***
    10:52:06.094 [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
    10:52:05.578 [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
    10:50:07.459 [CM504008]: Fax Service: registered as sip:888@192.168.1.100:5060 with contact sip:888@192.168.1.100:5100;user=phone
    10:46:57.750 [CM503008]: Call(45): Call is terminated
    10:46:43.189 [CM503007]: Call(45): Device joined: sip:10000@192.168.1.103:5060
    10:46:43.189 [CM503007]: Call(45): Device joined: sip:109@127.0.0.1:5070;rinstance=4e3cca1daf969ea5
    10:46:43.189 [CM505002]: Gateway:[Cavalier Phone Netowrk] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:8) 1.0.1.8] Transport: [sip:192.168.1.100:5060]
    10:46:43.157 [CM503002]: Call(45): Alerting sip:10000@192.168.1.103:5060
    10:46:40.517 [CM503004]: Call(45): Calling: PSTNline:2766666614@(Ln.10000@Cavalier Phone Netowrk)@[Dev:sip:10000@192.168.1.103:5060, Dev:sip:10001@192.168.1.103:5062, Dev:sip:10002@192.168.1.103:5064, Dev:sip:10003@192.168.1.103:5066]
    10:46:40.501 [CM503010]: Making route(s) to <sip:2766666614@192.168.1.100:5060>
    10:46:40.501 [CM505001]: Ext.109: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4526.0] Transport: [sip:192.168.1.100:5060]
    10:46:40.486 [CM503001]: Call(45): Incoming call from Ext.109 to <sip:2766666614@192.168.1.100:5060>
    10:45:35.567 [CM503008]: Call(44): Call is terminated
    10:45:28.724 [CM503007]: Call(44): Device joined: sip:10000@192.168.1.103:5060
    10:45:28.724 [CM503007]: Call(44): Device joined: sip:109@127.0.0.1:5070;rinstance=4e3cca1daf969ea5
    10:45:28.724 [CM505002]: Gateway:[Cavalier Phone Netowrk] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:8) 1.0.1.8] Transport: [sip:192.168.1.100:5060]
    10:45:28.692 [CM503002]: Call(44): Alerting sip:10000@192.168.1.103:5060
    10:45:28.630 [CM503004]: Call(44): Calling: PSTNline:2766666614@(Ln.10000@Cavalier Phone Netowrk)@[Dev:sip:10000@192.168.1.103:5060, Dev:sip:10001@192.168.1.103:5062, Dev:sip:10002@192.168.1.103:5064, Dev:sip:10003@192.168.1.103:5066]
    10:45:28.614 [CM503010]: Making route(s) to <sip:2766666614@192.168.1.100:5060>
    10:45:28.599 [CM505001]: Ext.109: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4526.0] Transport: [sip:192.168.1.100:5060]
    10:45:28.583 [CM503001]: Call(44): Incoming call from Ext.109 to <sip:2766666614@192.168.1.100:5060>
    10:45:15.318 [CM503008]: Call(43): Call is terminated
    10:45:15.303 [CM503015]: Call(43): Attempt to reach <sip:*80@192.168.1.100:5060> failed. Reason: Not Found
    10:45:15.303 [CM503014]: Call(43): No known route to target: <sip:*80@192.168.1.100:5060>
    10:45:15.287 [CM503010]: Making route(s) to <sip:*80@192.168.1.100:5060>
    10:45:15.287 [CM505001]: Ext.109: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4526.0] Transport: [sip:192.168.1.100:5060]
    10:45:15.271 [CM503001]: Call(43): Incoming call from Ext.109 to <sip:*80@192.168.1.100:5060>
    10:45:07.381 [CM504008]: Fax Service: registered as sip:888@192.168.1.100:5060 with contact sip:888@192.168.1.100:5100;user=phone
    10:45:03.116 [CM503008]: Call(42): Call is terminated
    10:45:03.100 [CM503015]: Call(42): Attempt to reach <sip:92762249610@192.168.1.100:5060> failed. Reason: Not Found
  5. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Can you confirm if this logging is from V6 or V7?
    It appears you have a STUN related issue. If you are using V7 and not using VOIP Providers OR Remote extensions, can you please turn off STUN from the Settings > Network > STUN tab and restart the 3CX PhoneSystem service.
