Problem to call outside with the MyDivert Operator
Discussion in '3CX Phone System - General' started by philduv, Sep 6, 2010.
  1. philduv
    Aug 19, 2010
    12
    I have still another problem with MyDivert, Betamax operators didn't give me this problem.
    The out calls are forbidden and I can receive calls (operator connected in green)
    Here is the log:
    14:43:24.484 [CM503020]: Normal call termination. Reason: Forbidden
    14:43:24.484 [CM503016]: Call(29): Attempt to reach <sip:%23500352621324490@192.168.1.2:5060> failed. Reason: Forbidden
    14:43:24.484 [CM503003]: Call(29): Call to sip:00352621324490@sip.mydivert.com:5060 has failed; Cause: 603 Declined; from IP:188.40.93.13:5060
    14:43:24.234 [CM503025]: Call(29): Calling VoIPline:00352621324490@(Ln.10004@mydivert)@[Dev:sip:001100194@sip.mydivert.com:5060]
    14:43:23.984 [CM503004]: Call(29): Route 1: VoIPline:00352621324490@(Ln.10004@mydivert)@[Dev:sip:001100194@sip.mydivert.com:5060]
    14:43:23.906 [CM503010]: Making route(s) to <sip:%23500352621324490@192.168.1.2:5060>
    14:43:23.906 [CM505001]: Ext.13: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.13679.0] PBX contact: [sip:13@192.168.1.2:5060]
    14:43:23.859 [CM503001]: Call(29): Incoming call from Ext.13 to <sip:%23500352621324490@192.168.1.2:5060>
    Thanks for your help.
    Note that I tried with adding the Request Line URI with the custom field with the username of the provider MyDivert, like for incoming calls (previous request in the forum), but it doesn't work.
    Ph. Duvivier
    10,869
    304
    They are "declining" to handle your call. It could be an incorrect number (length/digits), an unauthorized number (to a mobile?), you have no funds left in your account, any number of things. I would contact them directly and ask why they will not route a call based on the digits, 00352621324490, you are sending them.
