Problem to upgrade to 15.5 beta
Federico Moschini
Dear Support Team,
I cannot upgrade from web system manager to 15.5 beta.
Enclosed the log file.
I wait for your feedback.
Best regards,
Federico Moschini
  • Update3cx.log
Hello @Federico Moschini
You will need to type this command line in your terminal: apt-get update . Then you should go in the management console > Updates. Please let us know if this works.
In the windows version on 15.5 beta how do I white-list IP?
Hello @Mike Cruz,
You can do this from the Dashboard. Under PBX status > Blacklisted IPs > Add or Select the IP > Edit.
Get 3CX - Absolutely Free!
3CX
