Problem updating 3CX
Discussion in '3CX Phone System - General' started by jsadan, Nov 19, 2010.
  1. jsadan
    May 3, 2010
    91
    When I login to WINS 3CX Management console and go to 3CX updates the only one listed under 3CX Service Pack/Updates is a grayed out update for version 8
    Any ideas why I cant see the new service pack updates?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Probably because you are running v8 and not v9 which has current updates.
