Problem upgrading from V14 to V15
Discussion in '3CX Phone System - General' started by miaooaim, Sep 5, 2016.
  1. miaooaim
    Sep 5, 2016
    after the upgrade to V15 of the Phone System, when I try to save changes to the fax input trunk connected to a Patton 4112, I receive the follow error:
    [​IMG]
    This happen only with the fax trunk, the other connections are all ok.
    Whith the old parametrizzation the fax input works well. But if I try to change the password I can't save it definetively.
    What I have to do to solve the problem?
    Thank you.
    Regards
    Giuseppe
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    hi there,
    Do you have the same authentication ID in two trunks?
    empty value stills counts as the same.
    If yes please change it to the trunks external number
