Problem uploading VoiceApp
Discussion in '3CX Phone System - General' started by Lorenzo Benfenati, Feb 26, 2018.
  1. Lorenzo Benfenati
    Feb 26, 2018
    I've followed this guide https://www.3cx.com/docs/manual/cfd-building-projects/ and I have a problem.
    I've created and built the VoiceApp with the Call Flow Designer, but when I try to deploy the app I can't check the "Voice apps" checkbox inside the Call Queue editor, when i click on it nothing happens.
    How can I enable the checkbox?
  2. StefanW
    Jun 2, 2009
    1,222
    93
    do you have a PRO or ENT version?
  3. Lorenzo Benfenati
    Feb 26, 2018
    I've got a Standard Edition, no Call Designer for me :(
    I'm sorry to have bothered you, I should have checked my licence limitation before posting
  4. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    If required, you can always upgrade your license to Pro
    YiannisH_3CX likes this.
