problem when i call an inexistent outside number
Discussion in '3CX Phone System - General' started by gecomail, Apr 11, 2008.
  1. gecomail
    Apr 11, 2008
    14
    When i call a inexistent outside number (and use the voip line), past 30 seconds and then the 3cx recognize that the called number it's no good .
    In this 30 second the apparence of calling is the same that a call to good number.
    Someone know the solution at this problem ?
    Thank you Jury.
