Problem whit FQDN Resolution
Jose Lara
Gold Partner
On my Dashboard I have the information about my FQDN and the Public IP Address of my Internet Services,
but the remotes extension don't work And when I test from outside of my network using PING tool other IP respond to my FQDN.
please see pictures attached.
3CX have a tool or log file I can check for errors?
best regards,
Have you
enable external use of the extension - 'disable use of extension outside the lan' setting
Setup the necessary firewall rules - what does the firewall checker reports
What phones are you using and how are you provisioning them
I have deleted your attachments as having your FQDN and public IP displayed on public forums is never a good idea.
Have you passed the firewall checker? If you navigate to settings / network do you see the stun servers configured there?
Also have you tried restarting services to see if the IP updates correctly?
I have another ddns service runing on this site, and if I try to connect to Administration console using this url, connection pass susefull.
Get 3CX - Absolutely Free!
3CX
