problem with 3102
Discussion in '3CX Phone System - General' started by scammarano, May 31, 2007.
  1. scammarano
    Apr 17, 2007
    8
    i have one problem, when a finished the call (with pstn) the line is still open, and if i call the pstn number is busy.
    i think that this is related with the detection of the call is over (spa3102) but i don
  2. Anonymous
    Anonymous Guest
    http://www.d-d-d.com.au/3cx/3CX.htm
    I put a manual online that might help you out with that.
    Basically this is a combination with the on and off hook detection and the way you have configured your Call Progress Tones.
    Please advise in which country you have the SPA3102 installed and we take it from there.
  3. scammarano
    Apr 17, 2007
    8
    thanks for your response
    i'm in venezuela
    what changes i need to do.
    thanks again
