Problem with 3CX Phone System
Discussion in '3CX Phone System - General' started by bruck93, Jan 18, 2013.
  1. bruck93
    Jan 18, 2013
    Hello to everybody,
    I'm using 3CX Phone System, but i can't call or receive call.
    Now I don't know, but I saw that the Port / Status is not registered. Why ? Is that normal ?
    I'm using a Sonicwall gateway.
  2. tom_ch
    Jul 6, 2011
    69
    Let the Firewall checker run to see if everything's o.k. with your firewall configuration.
    And what says the 3CX Logs?
  3. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    First check the firewall checker on 3cx. I assume that you will get some errors... post the results here. We have 3cx with sipgate trunk which is passing through the sonicwall and it`s working fine... And yes, trunk status must be "Registered"
  4. bruck93
    Jan 18, 2013
    So, I launch the Firewall check.. I got many errors, all like this:
    Testing SIP Port 5060 using STUN server: stun.voip.eutelia.it:3478
    Resolving STUN server stun.voip.eutelia.it ... Resolved to: [83.211.9.232]
    [Test1] Reachability test ... Resolved Public IP: 88.87.124.182:13900
    STUN server stun.voip.eutelia.it has second address 83.211.9.235:3479
    [Test2] One on One Port Forwarding ... FAILED.
    No response received or port mapping is closed. Firewall check failed. This configuration is not supported
    What can I do ?
    It could be a problem of an ID and Password of the Sonicwall's port ?
    Because I know UT and PW of the Sonicwall, but I didn't configured it. I know only that work for my IP and all the port that I need are opened.
    Gateway and Voip Trunk status are "Not Registered"
