Problem with answering calls
Discussion in 'Windows' started by knurft06, Jan 18, 2009.
  1. knurft06
    Jan 18, 2009
    5
    Whan I call the softphone, it will ring and keeps on ringing even I answered the call. The other party sees that I answered this call and there is no sound transfer.
    Pressing the red-phone (on-hook) will stop the ringsignal (but not the call-session for the other party)
    The other party is a siemens C455IP.
    Any clue?
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Is their Siemens C455IP registered with the 3CX server?
    What version of 3CX is the server and what version of the 3CX softphone are you using?
    What OS are you using the softphone with?
  3. knurft06
    Jan 18, 2009
    5
    No the Siemens AND the softphone are NOT registed with a 3CX as they both can be used as an independed SIP-client.
    I am running XP on the machine, and the logfile shows
    [18:30:49] 3CX VoipClient Starting..
    [18:30:53] * newCall()- to freeline 0
    [18:30:53] GuiEvent - DoPlayRinging() - line 0
    [18:30:54] * ringing()
    [18:30:58] * stunCheckResult() - succesfull 82.215.27.223:26427 , attempts left=5
    [18:31:01] * acceptCall() - line 0
    [18:31:01] PhoneGui::AcceptCall() Accepting call on line 0
    [18:31:06] GuiEvent - DoStopPlaying() - line 0
    [18:31:06] * cancelCall() - line 0
    [18:31:28] * stunCheckResult() - succesfull 82.215.27.223:26427 , attempts left=5
    [18:31:33] * ended()
    [18:31:33] GuiEvent - DoStopPlaying() - line 0
    [18:31:49] PhoneGui::Shutdown()
    [18:31:49] GuiEvent - Shutdown()
    [18:31:49] * unregistered()
    [18:31:49] * Stop() - phone engine stoping
    [18:31:50] 3CX VoipClient Exiting.
    As you can see
    indicates to stop the ringing. It does not.
  4. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    If you use another SIP client like X-Lite can the call connect properly?
    What version of the 3CX softphone are you using?
  5. knurft06
    Jan 18, 2009
    5
    Yes it does. Did not test X-lite but tested a few others.
    The most recent one, downloaded from the site. 7.0.4184.0
  6. discovery1
    discovery1 Member
    Aug 4, 2008
    355
  7. knurft06
    Jan 18, 2009
    5
    I Upgraded the version. No change. Problem is still there.
    Any other clue? Can I extend logging to track down this issue?
  8. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    If it works with other SIP clients then it looks as though there is some incompatibility with the 3CX client.
    Are the client and the Siemens phone both registered with the same VOIP provider?
    Check the codec's that are being used and make sure they are both the same for each end.
  9. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    Hi, Knurft
    Sorry for delayed reply. Knurft, I cannot say if (and when) we will provide an update for the Voip Client, but definitely we will provide another release of the Voip Phone. Therefore, we try to remove from the Voip Phone as many as possible problems found in Client ver 7/6.
    Using the Voip Phone, I was able to simulate - not to reproduce - the issue you reported. So, if you are interested, please try it also, you may install it next to the Voip Client, since they don't conflicts each other: http://www.3cx.com/forums/new-3cx-softphone-beta-with-integrated-tunnel-8562.html
    If it has the same issue as you reported here, then I will ask you for further details. The problem you describe seems to be related with another one in V7 which has been fixed in the latest Voip Phone - the "multi echo" problem.
    vali
  10. knurft06
    Jan 18, 2009
    5
    That one works ok on this point.
    I am hitting the issue that I cannot use an real sip-adres like 123@domain.tld:5065 as a example
  11. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Hi, Knurft
    This is a good news 8)
    As I said on another topic here - this version of the Voip Phone is just a BETA, not the pre-, not the final- release one, and our aim is to make these two better than actual BETA, so... stay tuned 8)
    Cheers
    vali
  12. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Hi, Knurft
    Knurft, I've done some further investigations regarding the problem you prompted (phone keeps ringing after answering) and the good news is we found a quite serious issue leading to symptoms as you described (issue present in Client v6/v7 and in this BETA). Therefore, if you use the Voip Phone, I (strongly) advise you to update it when next release will be available.
    Thanks for your feedback
    vali
