Problem with API C#
Discussion in '3CX Phone System - General' started by itsystem, Oct 27, 2012.
  1. itsystem
    Jan 25, 2011
    15
    Hello!
    I need develope API code for connection to 3CX Phone System, but face on with problem.
    I'm need run that code with help "Windows Form Application":
    Code:
    private void button1_Click(object sender, EventArgs e)
                PBXConnection pbx = new PBXConnection();
                pbx.MakeCall("100", "101");
    When I click button1, get this error:
    on this code string PBXConnection pbx = new PBXConnection();
    I also try change string to:
    Code:
     PBXConnection pbx = new PBXConnection("127.0.0.1", 5482, "admin", "admin");
    and
    Code:
     PBXConnection pbx = new PBXConnection("127.0.0.1", 5482, "", "");
    but result error as above
    Visual Studio Project run locally (the same PC where installed 3CX Phone System).
    3CXPhoneSystem.ini
    Code:
    [General]
    AppPath=C:\Program Files\3CX PhoneSystem\
    WebServer=""
    pbxSLNIC=127.0.0.1
    FirstRun=False
    LogLevel=2
    ;msNoRTPFilter=0
    ;Msusetickcount=1
    [ConfService]
    AppName=DBProvider
    ConfPort=5485
    DBPort=5480
    confUser=DBServ
    dbUser=phonesystem
    DBHost=localhost
    DBName=phonesystem
    DefFile=Objects.cls
    confNIC=0.0.0.0
    confPass=pass
    dbPassword=6Rz_Ti-7&C3kM4g{xE$8
    PhoneSystem.ApplicationName = “Form1”
    PhoneSystem.ApplicationName = “3CX_Dialer”
    [MediaServer]
    Receivers=4
    Priorityclass=128
    Senders=4
    ;Sender3=0;15;-1
    ;Sender2=0;15;-1
    ;Sender1=0;15;-1
    ;Sender0=0;15;-1
    ;Receiver2=0;15;-1
    ;Receiver0=0;15;-1
    ;Receiver3=0;15;-1
    ;Receiver1=0;15;-1
    [CallReports]
    DATABASE=phonesystem
    USERNAME=logsreader
    PORT=5480
    DRIVER=PostgreSQL Unicode
    ReadOnly=1
    SERVER=localhost
    PASSWORD=5Zy+b&W4Qp6!3}wF?R8d
    Help please! :(
  2. itsystem
    Jan 25, 2011
    15
    8| Help Please!
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    PBXConnection is useless without notifications provided by PhoneSystem.Root
    OMSamples provides sample how to use MakeCall
    :eek:
  4. itsystem
    Jan 25, 2011
    15
    Of course, I will use notification provider, but I need only test MakeCall using my 3CX PS.
    Or PBXConnection() don't work without it???
  5. SY
    3CX Support
    Jan 26, 2007
    1,825
    In current version you must initialize connection to configuration server first.
  6. itsystem
    Jan 25, 2011
    15
    If are You can example please how this to do?
  7. SY
    3CX Support
    Jan 26, 2007
    1,825
    http://www.3cx.com/downloads/3CXCallControlAPI_v11.zip
    see folder OMSamples
  8. itsystem
    Jan 25, 2011
    15
    OK! Thank's!
  9. itsystem
    Jan 25, 2011
    15
    Thank You for advice for initial connection. All work OK!
    But I need develop some application which will be automatic dial procedure from list of external number and connection it with IVR internal number for automatically notify external users about something.
    I wrote code which start dial and connection with IVR number, but I need as anything monitoring state of current call and when it end or droped start dial to next item from list.
    I tried to understand how to do it and see "MyListner class" and Notification Monitor sample but unfortunately I can't figure out how to do it.
    Please explain how to do it ????
    Thank You!!!
  10. itsystem
    Jan 25, 2011
    15
    Help please!!! 8|
