Problem With Audio Codes Mp-404
Discussion in '3CX Phone System - General' started by ciavattip, May 16, 2008.
  1. ciavattip
    May 16, 2008
    Hi, i have a problem with audio codes mp-404; my 3cx, don't accept icoming call and i have this on log :
    [CM102001]: Authentication failed for SipReq: INVITE xxxxxxxxx@192.168.0.252:5060 tid=-93c-2415f8-5a403287 cseq=INVITE contact=xxxxxxxxxxxx@192.168.100.250:5060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings.
    Do you have a configuration guide for this appliance ??
  2. ciavattip
    May 16, 2008
    Hi, i am new for voip system, my 404, is registered on a 3cx pabx; this is not all ??
    I can make a outgoing call but, 404 on a incoming call, give the full msn number like prefix without "0" and the full number. I solve it with external numer on line configuration on 3cx pabx. But i have another problem; i have two Isdn Bri; I can not make a Did for incoming call because, Audio Codes, don't send a line numer but full msn number.
