Problem with autoAttendant since upgrade to v5.1
Discussion in '3CX Phone System - General' started by Andrew L, Feb 25, 2008.
  1. Andrew L
    Feb 13, 2008
    The autoAttendant does not function for incoming calls from two different voip providers. It works perfectly when I dial the internal number. I can direct calls to groups and individuals but not to the autoattendant. This worked perfectly in previous version.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Andrew,
    Which version is previous?
    Please specify VoIP providers.
  3. Andrew L
    Feb 13, 2008
    I rebooted my server and this solved the problem on this one issue. I did not think it was necessary, but I thought I would give it a try. Strangely I never had an issue on this 3CX phone system. Everything has worked flawlesssly except for this one issue. This is the best VOIP system I have seen. I just got started with it less than a month ago.
    Cheers
