- Joined
- May 2, 2012
- Messages
- 6
- Reaction score
- 0
i got a problem with function "ring my extension and my mobile at the same time" when using "Available 2" since last service pack (v11, sp3 build 28392.820). It was working well on v11, sp2 build 27588.780
we use the "Available 2" status because we discover that when using this status with "ring my extension and my mobile at the same time" AND with a SIP phone AND a mobile number set, the SIP phone AND mobile ring but mobile phone is also able to answer the call when SIP phone AND mobile phone ring at the same time before going to the forwarding rules. This is not hapening in "Available" status since the mobile phone just "ring" as normal then is transfered to the mobile phone using forwarding rules.
This "function" is REALLY usefull since me and some coworkers are often on the road for emergercy and don't have time (or forget ) to change our status to redirect phone call directly on our mobile phone. It make sure that if we are not in front of our SIP phone to aswer, we will answer using the mobile phone.
It is also usefull since we use the callcenter function. Let me explain :
When a call goes trough a call queue, each extension ring one after the other but does not reach the forwarding rules of the extension since the call need to be answered. Using "Available 2" status as describe will ring SIP phone AND mobile phone and provide us the possibility to answer the call using our mobile phone.
here is the log of a call made to extension 101 set to "available 2" status with "ring my extension and my mobile at the same time". Forwarding rules will transfer the call to the mobile phone.
the call goes like this :
1- i call the PBX
2- IVR for welcome is played so i dial the extension number
3- SIP phone ring but not the mobile phone
4- Since there is no answer, the call is transfered to the mobile phone directly
Here is the log of the call. Note that i've replace the phone number for security in the log.
I've been banging my head for weeks now since i have little time to check this issue.
Any ideas ?
1- i call the PBX
Code:
15-janv.-2013 13:59:33.148 [CM503007]: Call(C:819): Ivr:801 has joined, contact <sip:[email protected]:40600>
15-janv.-2013 13:59:33.146 [CM503007]: Call(C:819): Line:10000<<EXTERNAL-PHONE has joined, contact <sip:[email protected]:5060>
15-janv.-2013 13:59:33.143 L:819.2[Ivr] has joined to L:819.1[Line:10000<<EXTERNAL-PHONE]
15-janv.-2013 13:59:32.939 [CM503025]: Call(C:819): Calling T:Ivr:801@[Dev:sip:[email protected]:40600;rinstance=83ca7e0b251a58be] for L:819.1[Line:10000<<EXTERNAL-PHONE]
15-janv.-2013 13:59:32.928 [CM503027]: Call(C:819): From: Line:10000<<EXTERNAL-PHONE ("EXTERNAL-PHONE" <sip:[email protected]:5060>) to T:Ivr:801@[Dev:sip:[email protected]:40600;rinstance=83ca7e0b251a58be]
15-janv.-2013 13:59:32.928 [CM503004]: Call(C:819): Route 1: from L:819.1[Line:10000<<EXTERNAL-PHONE] to T:Ivr:801@[Dev:sip:[email protected]:40600;rinstance=83ca7e0b251a58be]
15-janv.-2013 13:59:32.928 [CM505003]: Provider:[Unlimitel] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Primus-Unlimitel] PBX contact: [sip:PBX-PHONE-LINE@OUR-IP:5060]
15-janv.-2013 13:59:32.926 [CM503001]: Call(C:819): Incoming call from Line:10000<<EXTERNAL-PHONE to <sip:[email protected]:5060>
15-janv.-2013 13:59:32.926 Line limit check: Current # of calls for line Lc:10000(@Unlimitel[<sip:[email protected]:5060>]) is 1; limit is 5
15-janv.-2013 13:59:32.836 [CM503012]: Inbound office hours rule (unnamed) for 10000 forwards to DN:801
15-janv.-2013 13:59:45.537 [CM503025]: Call(C:819): Calling T:Extn:101@[Dev:sip:[email protected]:53147;transport=tcp] for L:819.1[Line:10000<<EXTERNAL-PHONE]
15-janv.-2013 13:59:45.534 [CM503027]: Call(C:819): From: Line:10000<<EXTERNAL-PHONE ("EXTERNAL-PHONE" <sip:[email protected]:5060>) to T:Extn:101@[Dev:sip:[email protected]:53147;transport=tcp]
15-janv.-2013 13:59:45.534 [CM503004]: Call(C:819): Route 1: from L:819.1[Line:10000<<EXTERNAL-PHONE] to T:Extn:101@[Dev:sip:[email protected]:53147;transport=tcp]
15-janv.-2013 13:59:45.533 [CM505003]: Provider:[Unlimitel] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Primus-Unlimitel] PBX contact: [sip:PBX-PHONE-LINE@OUR-IP:5060]
15-janv.-2013 13:59:58.153 Currently active calls - 1: [819]
15-janv.-2013 14:00:05.665 [CM503025]: Call(C:819): Calling T:Line:10000>>MOBILE-PHONE@[Dev:sip:[email protected]:5060] for L:819.1[Line:10000<<EXTERNAL-PHONE]
15-janv.-2013 14:00:05.572 [CM503005]: Call(C:819): Forwarding: T:Line:10000>>MOBILE-PHONE@[Dev:sip:[email protected]:5060]
15-janv.-2013 14:00:05.572 Line limit check: Current # of calls for line Lc:10000(@Unlimitel[<sip:[email protected]:5060>]) is 1; limit is 5
15-janv.-2013 14:00:05.572 L:819.1[Line:10000<<EXTERNAL-PHONE] forwards call from Extn:101 to Out#:>>Rule{Rule for Unlimitel}>>MOBILE-PHONE based on rule Fwd[Custom 1/NoAnsw]
15-janv.-2013 14:00:05.572 L:819.1[Line:10000<<EXTERNAL-PHONE] failed to reach Extn:101, reason No Answer
15-janv.-2013 14:00:05.784 Leg L:819.3[Extn] is terminated: Cause: 487 Request Cancelled/INVITE from 192.168.10.249:53147
15-janv.-2013 14:00:05.783 [CM503003]: Call(C:819): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Cancelled/INVITE from 192.168.10.249:53147
15-janv.-2013 14:00:14.463 Leg L:819.2[Ivr] is terminated: Cause: BYE from 127.0.0.1:40600
15-janv.-2013 14:00:14.257 [CM503007]: Call(C:819): Line:10000>>MOBILE-PHONE has joined, contact <sip:[email protected]:5060>
15-janv.-2013 14:00:14.254 L:819.4[Line:10000>>MOBILE-PHONE] has joined to L:819.1[Line:10000<<EXTERNAL-PHONE]
15-janv.-2013 14:00:11.143 [CM505003]: Provider:[Unlimitel] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Primus-Unlimitel] PBX contact: [sip:PBX-PHONE-LINE@OUR-IP:5060]
15-janv.-2013 14:00:30.153 Currently active calls - 1: [819]
Any ideas ?
