- Joined
- May 28, 2008
- Messages
- 19
- Reaction score
- 0
I successfully connected two 3cx with bridge but I unable to make calls between office brunches. In test I call ext 222 (I dial 7222 due to outbound rules). I can see following error on caller side:
12:07:03.782 [CM503016]: Call(1926): Attempt to reach <sip:[email protected]> failed. Reason: Not Found
12:07:03.782 [CM503003]: Call(1926): Call to sip:[email protected]:5060 has failed; Cause: 404 User unknown.; from IP:192.168.1.5:5060
12:07:03.220 [CM503025]: Call(1926): Calling PBXline:222@(Ln.20000@Main)@[Dev:sip:192.168.1.5:5060]
12:07:03.173 [CM503004]: Call(1926): Route 1: PBXline:222@(Ln.20000@Main)@[Dev:sip:192.168.1.5:5060]
12:07:03.157 [CM503010]: Making route(s) to <sip:[email protected]>
12:07:03.157 [CM505001]: Ext.208: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:[email protected]:5060]
12:07:03.157 [CM503001]: Call(1926): Incoming call from Ext.208 to <sip:[email protected]>
And this on called side:
09:59:21.159 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.200:5060;branch=z9hG4bK-d8754z-2e0722318329eb64-1---d8754z-;rport=5060
Max-Forwards: 70
Contact: <sip:192.168.0.200:5060>
To: <sip:[email protected]:5060>
From: "Alexander Kitaev"<sip:192.168.1.5:5060>;tag=3e2f7b27
Call-ID: NDdkNmEwMjQxNmYwYmFhNzBmMTFlZDZlOWUwMmRjZmY.
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Proxy-Authorization: Digest username="20000",realm="3CXPhoneSystem",nonce="414d535c0201885863:8c94e2130d0146d65bce7c676e9ea867",uri="sip:[email protected]:5060",response="b575df407907e6d15ce612d6317ff7c8",algorithm=MD5
User-Agent: 3CXPhoneSystem 8.0.10708.0
Content-Length: 0
Remote-Party-ID: "Alexander Kitaev"<sip:Alex%[email protected]:5060>;party=calling
09:59:21.159 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE [email protected]:5060 tid=2e0722318329eb64 cseq=INVITE contact=192.168.0.200:5060 / 2 from(wire)
09:59:20.846 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
Via: SIP/2.0/UDP 192.168.0.200:5060;branch=z9hG4bK-d8754z-0354204fac00c51a-1---d8754z-;rport=5060
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 0
Max-Forwards: 70
CSeq: 2 INVITE
Content-Length: 0
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 0
