Problem with Broadvoice
Discussion in '3CX Phone System - General' started by jdcrowder, Jul 24, 2007.
  1. jdcrowder
    Jul 24, 2007
    All,
    My Broadvoice line registered perfectly fine but when I try and call in but when I answer my Linksys SPA921 my cell phone (which is calling my VoIP line). Not sure what the deal here is - maybe a codec issue?
    Also, I can't call out either. I have setup a Outbound Rule as per the Manual but it doesn't work...
    Any idea's?
    Cheers,
    Josh
