Problem with busy tones signal.
Discussion in '3CX Phone System - General' started by nashakhalov, Dec 1, 2009.
  1. nashakhalov
    Nov 23, 2009
    10
    I use VoIP gateway and 3 different VoiP providers which all give me different signals in case of busy number. For example, one provider says "call could not be established", second gives busy tone after 10 sec pause, third says "the number is busy" etc.
    I wonder if 3CX can substitute all these signals by its own?
    3cx v8.0.9532.468
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,578
    115
    For Incoming and Outgoing calls to and from your PBX, you can set the: Settings > General > Global Options > Play Busy Prompt When Busy and Disable the Option
    ( If you want to hear a Voice Prompt instead of the 3CX Busy Tone.)
    Some Providers have a weird / bad way of using early media when this option is Enabled / etc hearing audio over audio, so test it a bit by calling some busy numbers before enabling it permanently on your lines or enable Supression of Early media on your phones.
  3. nashakhalov
    Nov 23, 2009
    10
    Thanks! It's resolved!
