Problem with calls internal calls dropping
Discussion in '3CX Phone System - General' started by dopenkly, Jan 30, 2007.
  1. dopenkly
    Jan 25, 2007
    I'm using 3CX phone (softphone client) on all my extensions. On one extension (the same box that the server is on), I drop calls that were made from another extension. The calls usually last for about a minute and then just terminate. If I initiate the call from the box that has the server on it, the calls do not drop. The server status quotes : StratLink::eek:nHangUp: Call(C:11): got Hang-Up from Ext.101.
    Any ideas?
    ports 3478, 5060, 7000-7500, and 9000-9003 are forwarded
