Problem with DFL-800
Discussion in '3CX Phone System - General' started by fifi, Dec 31, 2010.
  1. fifi
    Dec 31, 2010
    Hello
    I have a big problem with my Firewall. It's a DFL-800 DLINK
    Here the results from the 3CX's Firewall checker :
    I don't know to create a static rule to forwarding port to 3CX
    Is anybody know the process to do it ?
    Thank's and happy new year
  2. dorksdelivered
    Apr 26, 2011
    Hello Fifi,
    I also have a DFL-800 and I am having the same problem, did you find a solution to this?
    I am happy to help you out if we can work on this together it would be great.
    Kind Regards,
    Joshua
  3. smb1
    smb1 New Member
    Mar 18, 2009
    104
    While this link is for a Linksys, the process would likely be very similar for a D-Link router.
    http://www.3cx.com/blog/voip-howto/linksys-router-configuration/
    The DFL-800 user guide is available at:
    http://files.dlink.com.au/Products/DFL-800/Manuals/NetDefendOS_2.26_Firewall_UserManual_v1.10.pdf
    I believe the information you are looking for is on page 129 of that manual.
