Problem with Digital Receptionist v7
Discussion in '3CX Phone System - General' started by Driss, Jan 6, 2009.
  1. Driss
    Jan 6, 2009
    5
    I'm having problems configuring the Digital Receptionist in version 7. As soon as the an external call comes through the DID I get error saying 'an error occured in ivr session, sorry'.
    I'm running Windows Server 2003 SBS and fresh installation of 3cx v7. all ports are open correctly, with the firewall check all passed. If I set the DID to call an extention number it goes straight through (DR has been configured with an ivr recording). Extention numbers are using 3 digits.
    below is a list of the system log
    22:23:35.266|.\Line.cpp(311)|Log2||LineCfg::getInboundTarget:[CM503012]: Inbound out-of-office hours rule for 10000 forwards to DN:800<br>
    22:23:35.407|.\CallCtrl.cpp(135)|Log2||CallCtrl::eek:nIncomingCall:[CM503001]: Call(8): Incoming call from 07500777***@(Ln.10000@VOIPFONE) to <sip:800@192.168.100.1:5060><br>
    22:23:35.407|.\Line.cpp(1110)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[VOIPFONE] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Voipfone Sip Network] Transport: [sip:192.168.1.253:5060]<br>
    22:23:35.407|.\CallCtrl.cpp(295)|Log3||CallCtrl::eek:nSelectRouteReq:[CM503010]: Making route(s) to <sip:800@192.168.100.1:5060><br>
    22:23:35.407|.\CallCtrl.cpp(404)|Log2||CallCtrl::eek:nSelectRouteReq:[CM503004]: Call(8): Calling: Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=c93f90a69d0d644f]<br>
    22:23:35.922|.\CallCtrl.cpp(212)|Log3||CallCtrl::eek:nAnsweredCall:[CM503002]: Call(8): Alerting sip:800@127.0.0.1:40600;rinstance=c93f90a69d0d644f<br>
    22:23:35.922|.\Extension.cpp(922)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.800: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] Transport: [sip:127.0.0.1:5060]<br>
    22:23:35.938|.\CallCtrl.cpp(524)|Log2||CallCtrl::eek:nLegConnected:[CM503007]: Call(8): Device joined: sip:07500777***@195.189.173.10:5060<br>
    22:23:35.938|.\CallCtrl.cpp(524)|Log2||CallCtrl::eek:nLegConnected:[CM503007]: Call(8): Device joined: sip:800@127.0.0.1:40600;rinstance=c93f90a69d0d644f<br>
    22:23:38.922|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.101: new contact is registered. Contact(s): [sip:101@192.168.100.29:5060/101]<br>
    22:23:41.766|.\Call.cpp(760)|Log2||Call::Terminate:[CM503008]: Call(8): Call is terminated<br>
    22:23:42.391|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.103: new contact is registered. Contact(s): [sip:103@192.168.100.29:5060/103, sip:103@192.168.100.30:5060/103]<br>
    22:23:48.360|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.102: new contact is registered. Contact(s): [sip:102@192.168.100.30:5060/102]<br>
    22:24:07.032|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.101: new contact is registered. Contact(s): [sip:101@192.168.100.29:5060/101]<br>
    22:24:10.500|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.103: new contact is registered. Contact(s): [sip:103@192.168.100.29:5060/103
    Below is the list of the ivr log;
    22:23:36.047|0e7c|(0):Error! Module '3CX.com.vxi'. Error ID 999. messageXML parsing error in file http://localhost:5484/ivr_start.aspx?IVRHandlerFROM=07500777666&IVRHandlerMENU=800&IVRHandlerTO=800&ISID=From_07500777666_To_800_Menu_800_%230%2F6, line 1: Invalid document structure
    22:23:36.047|0e7c|(0):Error! Module '3CX.com.vxi'. Error ID 205. urihttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=07500777666&IVRHandlerMENU=800&IVRHandlerTO=800&ISID=From_07500777666_To_800_Menu_800_%230%2F6
    22:23:36.047|0e7c|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    22:23:41.719|0e7c|.\VXIMachine.cpp(1704):IvrDll, VXIMachine::EndSession(), Warning! Session 0x00C5F980 not found
    Any help would be gratefully received
    Regards
    Driss
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there.
    There are a couple of issues with the IVR which will be addressed with a maintenance release due shortly that may help address this for you.
    Meanwhile, if you could do the following:
    1. set logging to verbose
    2. restart all services
    3. generate a call that shows this issue
    4. generate a support info file and attach it to this ticket
    ...we will have a look at it and try to help addressing the issue.
    Regards
    Kevin
  3. Driss
    Jan 6, 2009
    5
    Hi Kevin,
    Thanks for the update, I've attached the support log file.
    Regards
    Driss
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    We are looking into this. Thanks for the information.
    Regards
    Kevin
  5. kevin
    kevin Member
    Nov 23, 2006
    316
    Please advise whether your IIS install has HTML compression turned on or off.
    If its on, please try turning it off and advise whether this resolves things for you.
    Regards
    Kevin
  6. Driss
    Jan 6, 2009
    5
    We have partial success!
    Disabling compression did the trick. Now calls are answered by the DR but when an option is selected other than repeat prompt I get the the same error' an error occured in ivr session, sorry'
    I've generated another log file and attached it.
    Thanks for you help so far.
    Driss
  7. Driss
    Jan 6, 2009
    5
    Just to follow up, I only disabled compression on the 'ivr' site and not the whole iis installation.
    Regards
    Driss
  8. tommyw
    Jan 9, 2009
    5
    I have the same problem after upgrading to v7. Call-by-name works but is is not possible to dial the extension directly. I checked the HTML compression and it is off. Unfortunately I have no errors in log although I set it on verbose. Also tried setting up another IVR but it gives the same error. This occurs both with external and internal calls.
    Hope the maintenance package comes soon available because the users are getting agitated :twisted:
  9. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    There are no logs attached. I need them to look at this any further.
    Also, are you using the default promptset? Or have you made any customisations?
    Also, if you disable HTTP compression for all of IIS temporarily, does the problem go away?
    Regards
    Kevin
  10. Driss
    Jan 6, 2009
    5
    Hi Keven
    Solved again. It was configured to use the UK English prompt set so I changed back to the default English prompt set and now all is well.
    FYI: I changed back to the UK English prompt set and it still worked.
    Thanks for all of help.
    Regards
    Driss
  11. tommyw
    Jan 9, 2009
    5
    I cannot see any errors in log but here it is anyway
    09:25:50.604 [CM503008]: Call(29): Call is terminated
    09:25:40.526 Session 32263 of leg C:29.1 is confirmed
    09:25:40.166 [CM503007]: Call(29): Device joined: sip:8000@127.0.0.1:40600;rinstance=fb1ba9495d185c78
    09:25:40.166 [CM503007]: Call(29): Device joined: sip:2244@192.168.32.29:5060;user=phone
    09:25:40.151 [MS210005] C:29.1:Answer provided. Connection(proxy mode):192.168.32.124:7120(7121)
    09:25:40.151 [MS210001] C:29.2:Answer received. RTP connection: 127.0.0.1:40640(40641)
    09:25:40.151 Remote SDP is set for legC:29.2
    09:25:40.135 [CM505001]: Ext.8000: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] Transport: [sip:127.0.0.1:5060]
    09:25:40.119 [CM503002]: Call(29): Alerting sip:8000@127.0.0.1:40600;rinstance=fb1ba9495d185c78
    09:25:39.541 [MS210004] C:29.2:Offer provided. Connection(proxy mode): 127.0.0.1:7122(7123)
    09:25:39.526 [CM503004]: Call(29): Calling: Ext:Ext.8000@[Dev:sip:8000@127.0.0.1:40600;rinstance=fb1ba9495d185c78]
    09:25:39.526 [CM503010]: Making route(s) to <sip:8000@192.168.32.124>
    09:25:39.526 [MS210000] C:29.1:Offer received. RTP connection: 192.168.32.29:32722(32723)
    09:25:39.510 Remote SDP is set for legC:29.1
    09:25:39.510 [CM505001]: Ext.2244: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7940G/7.5] Transport: [sip:192.168.32.124:5060]
    09:25:39.510 [CM503001]: Call(29): Incoming call from Ext.2244 to <sip:8000@192.168.32.124>
    09:25:39.323 [CM500002]: Info on incoming INVITE:
    INVITE sip:8000@192.168.32.124 SIP/2.0
    Via: SIP/2.0/UDP 192.168.32.29:5060;branch=z9hG4bK3863fc31
    Max-Forwards: 70
    Contact: <sip:2244@192.168.32.29:5060>
    To: <sip:8000@192.168.32.124>
    From: "2244"<sip:2244@192.168.32.124>;tag=000d65368b8b01cf3ea1571e-014ca9c2
    Call-ID: 000d6536-8b8b001f-3176ef5b-2d1b1214@192.168.32.29
    CSeq: 102 INVITE
    Expires: 180
    Date: Mon, 12 Jan 2009 08:25:39 GMT
    Proxy-Authorization: Digest username="2244",realm="3CXPhoneSystem",uri="sip:8000@192.168.32.124",response="8acd3765d8f6fcc8717d2203e1938f84",nonce="12876222339:cc1dd6a365695a93f25dd8345498a049",algorithm=MD5
    User-Agent: Cisco-CP7940G/7.5
    Content-Length: 0
    I've been trying to switch between different prompt sets without success. The same "an error quit IVR session, sorry" always.
    What I'm worried about is that our upgrade insurance end at Jan 17th. If a patch can be provided which can be installed not as an upgrade but as an executable etc, I'd be very grateful.
  12. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    Please be aware that a maintenance release will be made available in the coming days. Since the Major version number will still be Version 7, it will be available to all users who are already on Version 7, and is not dependent on having Upgrade Insurance.
    Several fixes will be implemented with this maintenance release.
    If after the release you still have issues, please revive this post and provide the full Support Info file after taking the pbx to verbose mode and restarting all services - we will look into the issue to provide some direction.
    Regards
    Kevin
  13. tommyw
    Jan 9, 2009
    5
    Whooh... thank you so much for the info!! :lol:
    Is it so that if I do not restart the services the verbose mode will not activate, i.e. it is not enough just to set verbose mode without restarting the services?
  14. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    Setting to verbose is insufficient. The PBX will only go to verbose logs after a service restart.
    Regards
    Kevin
  15. tommyw
    Jan 9, 2009
    5
    This is the log in verbose mode, cannot see anything that would help me
    08:50:30.053 [CM503008]: Call(3): Call is terminated
    08:50:18.991 Session 2353 of leg C:3.1 is confirmed
    08:50:18.584 [CM503007]: Call(3): Device joined: sip:8000@127.0.0.1:40600;rinstance=b4695381660cf310
    08:50:18.584 [CM503007]: Call(3): Device joined: sip:2244@192.168.32.29:5060;user=phone
    08:50:18.584 [MS210005] C:3.1:Answer provided. Connection(proxy mode):192.168.32.124:7012(7013)
    08:50:18.569 [MS210001] C:3.2:Answer received. RTP connection: 127.0.0.1:40610(40611)
    08:50:18.569 Remote SDP is set for legC:3.2
    08:50:18.553 [CM505001]: Ext.8000: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX MakeCall Helper;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX MakeCall helper] Transport: [sip:127.0.0.1:5060]
    08:50:18.553 [CM503002]: Call(3): Alerting sip:8000@127.0.0.1:40600;rinstance=b4695381660cf310
    08:50:18.037 [MS210004] C:3.2:Offer provided. Connection(proxy mode): 127.0.0.1:7014(7015)
    08:50:18.037 [CM503004]: Call(3): Calling: Ext:Ext.8000@[Dev:sip:8000@127.0.0.1:40600;rinstance=b4695381660cf310]
    08:50:18.037 [CM503010]: Making route(s) to <sip:8000@192.168.32.124>
    08:50:18.022 [MS210000] C:3.1:Offer received. RTP connection: 192.168.32.29:21230(21231)
    08:50:18.022 Remote SDP is set for legC:3.1
    08:50:18.022 [CM505001]: Ext.2244: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7940G/7.5] Transport: [sip:192.168.32.124:5060]
    08:50:18.006 [CM503001]: Call(3): Incoming call from Ext.2244 to <sip:8000@192.168.32.124>
    Anyway, thanks for all your help you've provided!
  16. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    To obtain all the verbose logs, you will need to generate a Support Info file and attach it to the post. That way we can understand better at which point in the process a failure may have occurred.
    Regards
    Kevin
  17. tommyw
    Jan 9, 2009
    5
    I just updated to v7.0.4744.0 and now everything seems to be working. Thank You for addressing this quickly :lol:
