Problem with DTMF
Discussion in '3CX Phone System - General' started by Arkasha18, Nov 6, 2007.
  1. Arkasha18
    Nov 6, 2007
    Good afternoon.
    We have some problems with DTMF. We have FXO voip router D-link DVG-6004S with connected analog phone line. 3CX doesn't get DTMF-signals from router.
    Couldn't you suggest must it work or there is no support of it in your programm?
    All installations about DTMF what I've found are:
    Dial Wait Timeout [1 - 60 s]
    Inter Digits Timeout [1 - 60 s]
    Minimum DTMF ON Length [40 - 500 ms]
    Minimum DTMF OFF Length [40 - 500 ms]
    DTMF Detection Sensitivity (less)1 2 3 4 5 (more)
    Enable Out-of-Band DTMF 0-1
    Enable Hook Flash Event 0-1
    RFC 2833 Payload Type 101 or SIP Info
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hi.
    Take a look at this
    http://www.3cx.com/forums/categories-1/3cx-product-and-company-announcements-and-hotfixes-2/dtmf-recognition-with-3cx-phone-system-1296/
  3. Arkasha18
    Nov 6, 2007
    Thanks, my problem was in the codec :)
  4. Mori
    Mori New Member
    Mar 23, 2007
    223
    Your welcome.
    Nice to be of assistance 8)
  5. Victor
    Dec 4, 2006
    10
    Help DVG-6004S
    Hello Friend as I can do to disable answering the DVG-6004S and to answer the 3CX and call an annex. Thanks for the help
  6. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hi.
    Not quite shure what you mean here.
    Can you be more specific?
  7. Victor
    Dec 4, 2006
    10
    Help DVG-6004S
    Hello
    The DVG-6004S this answering the incoming call and not 3CX, I disable the answering equipment DVG-6004S and to answer the central 3CX calls you could help me.
    Thank you
    Victor :oops:
  8. Mori
    Mori New Member
    Mar 23, 2007
    223
    uh.. You got me there.
    Im not familiar with the DVG-6004S, so we better leave this arena for someone who does.
    Sorry. :wink:
  9. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Victor,
    Enable the hotline feature at your DVG-6004S. Then define the hotline number to FXO ports . DVG6002S will divert the calls to the assigned hotline number.
