Problem with email configuration not work
Discussion in '3CX Phone System - General' started by pdonald, May 31, 2017.
  1. pdonald
    May 31, 2017
    After put on ->settings->email, the smtp server email and password, click on test button and don't receive any email.
    Try to put ssl with port after domain smtp xxx.xxxx.xxx:587 and after save, when return to menu the port desapear.
    can you help?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @pdonald
    The port disappears because when you enable SSL/TLS the default port is 587 so there is no need for the port to be there.
    If you use a different port then the port will remain visible.
    when you click on the test button do you get an error? Also is this a windows or a linux PBX? Is it local or is it installed on the cloud?
    Try to use a gmail account as a test to narrow down the cause of the issue
    https://www.3cx.com/blog/docs/gmail-mail-server/
  3. business54
    Apr 20, 2016
    55
    I'm also seeing issues: Windows install, Ver 15 using gmail.
    Error: The remote certificate is invalid according to the validation procedure.
    I'm using the same email settings as current system configs that are working. I did use the 3CX server to access gmail also.
  4. Zacharias_3CX
    Zacharias_3CX Support Team
    May 4, 2017
    32
    Hello @business54
    Can you send me a private message with a screenshot of the configuration and the error message you are referring to?
  5. StefanW
    Jun 2, 2009
    1,167
    75
    it sounds like you firewall inspects smtp connections and replaces googles ssl cert with an intermediate of your firewall... this is essentially what the message tells you...
