problem with email notification
Discussion in 'Windows' started by KenC, May 3, 2014.
  1. KenC
    Mar 29, 2012
    85
    After reinstallation problem was overcome, I've got the v11 running again. However, I no longer get email notifications. On the extention pages of the console the "email options" field label is grey. If I uncheck "enable voicemail" then recheck it, the "email options" field is enabled, but after saving the page it is shaded again when I return to the page, and I still don't get the email notifications.
    How do I troubleshoot this?
    Thank you
  2. KenC
    Mar 29, 2012
    85
    needed to reenter registration key.
