- Joined
- Apr 19, 2011
- Messages
- 9
- Reaction score
- 0
Hi!
Have problem with forward to outside.
We need that outside calls must be forwarded to my mobile when in autoattendant pressed "1".
I made ext 222 and set it to forward to mobile phone if no answer 1 second.
Tested from other ext - dialed 222 and after 1 second call forwarded to my mobile phone.
Then i set autoattendant to forward to ext 222 if pressed "1".
And it does not work! It says "unable to forward call".
Please help!
Logs:
Please help!
Logs:
Code:
14:55:53.414 [CM503008]: Call(26): Call is terminated
14:55:50.624 [CM503016]: Call(26): Attempt to reach <sip:[email protected]:5060> failed. Reason: Forbidden
14:55:50.622 [CM503003]: Call(26): Call to sip:[email protected]:5060 has failed; Cause: 403 Forbidden; from IP:10.99.201.242:5060
14:55:50.282 [CM503025]: Call(26): Calling VoIPline:89218589989@(Ln.10001@Severen2)@[Dev:sip:[email protected]:5060]
14:55:50.273 [CM503003]: Call(26): Call to sip:[email protected]:5060 has failed; Cause: 403 Forbidden; from IP:10.99.201.242:5060
14:55:49.896 [CM503025]: Call(26): Calling VoIPline:89218589989@(Ln.10000@Severen)@[Dev:sip:[email protected]:5060]
14:55:49.844 [CM503005]: Call(26): Forwarding: VoIPline:89218589989@(Ln.10001@Severen2)@[Dev:sip:[email protected]:5060]
14:55:49.840 [CM503005]: Call(26): Forwarding: VoIPline:89218589989@(Ln.10000@Severen)@[Dev:sip:[email protected]:5060]
14:55:49.839 [CM503016]: Call(26): Attempt to reach <sip:[email protected]:5060> failed. Reason: Not Registered
14:55:49.839 [CM503017]: Call(26): Target is not registered: Ext.222
14:55:49.839 [CM503010]: Making route(s) to <sip:[email protected]:5060>
14:55:46.136 [MS211000] C:26.1: 10.99.201.244:18114 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
14:55:40.666 Currently active calls - 1: [26]
14:55:37.960 [CM503007]: Call(26): Device joined: sip:[email protected]:40600;rinstance=e41de737652b507a
14:55:37.958 [CM503007]: Call(26): Device joined: sip:[email protected]:5060
14:55:37.952 [CM505001]: Ext.805: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:[email protected]:5060]
14:55:37.952 [CM503002]: Call(26): Alerting sip:[email protected]:40600;rinstance=e41de737652b507a
14:55:37.798 [CM503025]: Call(26): Calling Ext:Ext.805@[Dev:sip:[email protected]:40600;rinstance=e41de737652b507a]
14:55:37.761 [CM503004]: Call(26): Route 1: Ext:Ext.805@[Dev:sip:[email protected]:40600;rinstance=e41de737652b507a]
14:55:37.761 [CM503010]: Making route(s) to <sip:[email protected]:5060>
14:55:37.760 [CM505003]: Provider:[Severen] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [MERA MVTS3G v.4.3.0-31] PBX contact: [sip:[email protected]:5060]
14:55:37.752 [CM503001]: Call(26): Incoming call from 9218589989@(Ln.10000@Severen) to <sip:[email protected]:5060>
14:55:37.745 [CM503012]: Inbound out-of-office hours rule (8124956941) for 10000 forwards to DN:805
14:55:21.756 [CM503008]: Call(25): Call is terminated
14:55:18.352 [CM503016]: Call(25): Attempt to reach <sip:[email protected]:5060> failed. Reason: Forbidden
14:55:18.350 [CM503003]: Call(25): Call to sip:[email protected]:5060 has failed; Cause: 403 Forbidden; from IP:10.99.201.242:5060
14:55:18.030 [CM503025]: Call(25): Calling VoIPline:89218589989@(Ln.10001@Severen2)@[Dev:sip:[email protected]:5060]
14:55:18.021 [CM503003]: Call(25): Call to sip:[email protected]:5060 has failed; Cause: 403 Forbidden; from IP:10.99.201.242:5060
14:55:17.754 [CM503025]: Call(25): Calling VoIPline:89218589989@(Ln.10000@Severen)@[Dev:sip:[email protected]:5060]
14:55:17.698 [CM503005]: Call(25): Forwarding: VoIPline:89218589989@(Ln.10001@Severen2)@[Dev:sip:[email protected]:5060]
14:55:17.696 [CM503005]: Call(25): Forwarding: VoIPline:89218589989@(Ln.10000@Severen)@[Dev:sip:[email protected]:5060]
14:55:17.695 [CM503016]: Call(25): Attempt to reach <sip:[email protected]:5060> failed. Reason: Not Registered
14:55:17.695 [CM503017]: Call(25): Target is not registered: Ext.222
14:55:17.694 [CM503010]: Making route(s) to <sip:[email protected]:5060>
14:55:14.034 [MS211000] C:25.1: 10.99.201.243:15684 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
14:55:09.832 [CM503007]: Call(25): Device joined: sip:[email protected]:40600;rinstance=e41de737652b507a
14:55:09.829 [CM503007]: Call(25): Device joined: sip:[email protected]:5060
14:55:09.825 [CM505001]: Ext.805: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:[email protected]:5060]
14:55:09.824 [CM503002]: Call(25): Alerting sip:[email protected]:40600;rinstance=e41de737652b507a
14:55:09.671 [CM503025]: Call(25): Calling Ext:Ext.805@[Dev:sip:[email protected]:40600;rinstance=e41de737652b507a]
14:55:09.630 [CM503004]: Call(25): Route 1: Ext:Ext.805@[Dev:sip:[email protected]:40600;rinstance=e41de737652b507a]
14:55:09.630 [CM503010]: Making route(s) to <sip:[email protected]:5060>
14:55:09.629 [CM505003]: Provider:[Severen] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [MERA MVTS3G v.4.3.0-31] PBX contact: [sip:[email protected]:5060]
14:55:09.626 [CM503001]: Call(25): Incoming call from 9218589989@(Ln.10000@Severen) to <sip:[email protected]:5060>
14:55:09.619 [CM503012]: Inbound out-of-office hours rule (8124956941) for 10000 forwards to DN:805
