Problem with Grandstream GXW-4104
Discussion in '3CX Phone System - General' started by erik, Jul 12, 2007.
  1. erik
    May 24, 2007
    6
    I have GXW-4104 and I've configured it according instruction in the 3CX site.
    There is description about hang upping of incoming calls from PSTN after 30 seconds. I have this situation, but the port hang up completly, after it 3CX system says that destination busy (but the status is green) and incoming calls from PSTN not going through (gxw-4104 doesn't see incoming call, LED is not flashing). Moreover distance rebooting of gxw-4104 dosen't take any effect, I have to manually switch off/on power supply to reboot device.
    Is this Hang Up which is described in the site ?
    Or I have something wrong ?
  2. erik
    May 24, 2007
    6
    I've made upgrade of software version of GXW, now Programm- 1.0.0.55,
    Loader-1.0.0.6, Boot-1.0.0.18.
    And the problem with completly hang upping of port disappered.
    But appeared another starnge situation.
    1. In case of incomming call from PSTN routed direct to extention (without digital receptionist) after 15 sec GXW sends CANCEL, but not hung up the PSTN line, so PSTN line keeping to ring and calls to extention repeats after few seconds. It repeats til PSTN line hangs up. So GXW hang up line after 15 seconds, it's highly short time. The trace form Server Status :
    17:54:37.640 StratInOut::eek:nHangUp [CM104007] Call(89): Call from Ln:222@gxw to 116 has been terminated by Ln:222@gxw; cause: CANCEL; from IP:192.168.0.60
    17:54:27.140 CallConf::eek:nProvisional [CM103003] Call(89): Ext.116 is ringing
    17:54:26.984 CallConf::eek:nIncoming [CM103002] Call(89): Incoming call from unknown (Ln:222@gxw) to sip:222@192.168.0.3
    17:54:17.406 StratInOut::eek:nHangUp [CM104007] Call(88 ): Call from Ln:222@gxw to 116 has been terminated by Ln:222@gxw; cause: CANCEL; from IP:192.168.0.60
    17:54:02.250 CallConf::eek:nProvisional [CM103003] Call(88 ): Ext.116 is ringing
    17:54:02.015 CallConf::eek:nIncoming [CM103002] Call(88 ): Incoming call from unknown (Ln:222@gxw) to sip:222@192.168.0.3
    17:53:52.437 StratInOut::eek:nHangUp [CM104007] Call(87): Call from Ln:222@gxw to 116 has been terminated by Ln:222@gxw; cause: CANCEL; from IP:192.168.0.60
    17:53:37.343 CallConf::eek:nProvisional [CM103003] Call(87): Ext.116 is ringing
    17:53:37.109 CallConf::eek:nIncoming [CM103002] Call(87): Incoming call from unknown (Ln:222@gxw) to sip:222@192.168.0.3
    2. If I made the Digital Receptional, an incoming call from PSTN is transfered to selected extension but it's keeping stay ringing untill extension hook off, if calling party hang up the PSTN line the called extension keep satying ringing, and the setting at Extension No answer after seconds not taking effect.
    Could anybody help me ?
    Thanks.
