Problem with hotdesking
Discussion in '3CX Phone System - General' started by Kevinrek, Jan 15, 2018.
  1. Kevinrek
    Nov 22, 2017
    9
    Hey,
    I have a problem with one of our customers.
    We have installed a new pbx and fully updated this customer.
    This customer has installed a sbc on location and this is also the latest version.
    The following phones are used: yealink t42s.
    The devices have the new firmware that is supplied by 3cx.
    We have prepared the devices via the new hotdesking function of 3cx.
    The provisioning of the devices with the hotdesking template is going well, but when we then want to log in with the details of an extension, things are not going well.
    The telephone indicates that I am logged in successfully and then does nothing. When I look at the PBX, I see that the extension is logged in on the device, but the settings are not retrieved by the device. After a restart of the device the settings are retrieved and it works, but the devices log off without any reason.
    Do you have any idea what the problem can be here?
    I hope you can help me
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    Hi Kevinrek,
    Please use this guide, it should assist:
    https://www.3cx.com/docs/hot-desking/
    In particular are you getting the "forbidden message" I assume from what you have said the dial code to login works correctly, it just does not do anything when the dial-code is entered ? please confirm.
  3. Kevinrek
    Nov 22, 2017
    9
    Yes thanks, but that is exactly the way we have installed it, but it does not work.
    When logging in via the dial code I get to hear '' you are logged in successfully the device is reset to your personal settings ''
    When I then restart the device, the settings are retrieved, but without restarting the device nothing happens
  4. eddv123
    Aug 15, 2017
    1,218
    174
    Also be aware that Hotdesking is only available in the PRO and Enterprise licence editions.
    Also ensure that you are running the latest supported firmware for these phones.
    You can find the latest supported firmware here: https://www.3cx.com/support/phone-firmwares/
  5. Kevinrek
    Nov 22, 2017
    9
    Yes, you know that a pro license is used.
    In the first post I gave the following information:
  6. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    I gave up on hotdesk with my Yealink. Htek works fine...Yealink wouldn't reboot or populate BLFs.
  7. Kevinrek
    Nov 22, 2017
    9
    It is very strange because we have several customers with a yealink t40g where everything goes well with hotdesking.
  8. pact
    pact New Member
    Dec 16, 2009
    202
    36
    We have experienced the same scenario, the phone will not auto-reprovision, a restart of the phone will provision correctly. (when over SBC).
    It's worked ok on some networks and not on others... so we're also moving away from allowing Hotdesking from anything but local PBX installations.
  9. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Please make sure that when you assign the phone to the Hot desking extension you do it through PnP and not by manually pasting the provisioning link into the phone.
  10. proofficemhellmann
    Jan 25, 2016
    The same problem here at all, but I solved the problem for the moment.
    Very Important is that the pbx can contact the phone directly via it's ip adress.
    That won't work over the SBC only.
    So if you use a cloud server and a SBC you have to use a vpn in the network so that the PBX can communicate with the telephone and all works fine.
    Tested it with snom yealink.
