Solved problem with incoming calls V15.0.71
Discussion in 'Android' started by paurus, Apr 2, 2017.
  1. paurus
    Jan 20, 2017
    67
    6
    Hello.
    I have a problem with incoming calls.
    When call is coming there is “GCM response: OK OK” in log file.
    I get incoming calls and push mails when 3CX is closed or phone is in sleep mode.
    I can receive incoming calls after 7 min in sleep mode, but I don’t get it after 10 min (there is “GCM response: OK OK” in log file). WhatsApp calls are always received.
    All phone settings are checked: 3CX pushes are turned on, low power mode are turned off.
    I have checked it in the network (WiFi) and out of it (LTE).
    I have added new user, request welcome email has been sent to his Android phone.
    User has installed and checked 3CX Client. Problem is the same.
    He connected to another network (WiFi).
    Deleting and recreating GCM didn’t help.
    When call is failed there are following in log file:
    03-31 18:20:05.525 31654 31654 I chatty : uid=10007(com.tcx.sipphone14) expire 53 lines
    03-31 18:20:05.649 31654 31676 I chatty : uid=10007(com.tcx.sipphone14) expire 6 lines
    03-31 18:20:25.103 31654 31654 I chatty : uid=10007(com.tcx.sipphone14) expire 22 lines
    03-31 18:20:25.118 31654 31678 I chatty : uid=10007(com.tcx.sipphone14) expire 6 lines
    3cx Phone System V15 SP5
    APP_VERSION:
    150071
    PACKAGE_NAME:
    com.tcx.sipphone14
    PHONE_MODEL:
    E5823
    ANDROID_VERSION:
    7.0
    BRAND:
    Sony
    PRODUCT:
    E5823
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    245
    12
  3. paurus
    Jan 20, 2017
    67
    6
    we have a static external IP, he has not changed. in paragraph 10 of the restrictions is not installed.
  4. paurus
    Jan 20, 2017
    67
    6
    when problems with IP GCM meets “GCM Response: Unauthorized Unauthorized”
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,486
    357
    To me is sounds like and android power management issue. Make sure that you have excluded the 3CX client from power saving options. Especially with Android 7.0 this is could be an issue with the new doze settings. To turn it off on mu device i need to go to battery settings then battery optimization ans exclude the 3CX client. Every device is different though depending on the manufacturer and the android skin.
  6. paurus
    Jan 20, 2017
    67
    6
    Found the problem. Optimization is turned off - calls do not come. Turned on optimization and the calls come.
  7. YiannisH_3CX
    May 10, 2016
    5,486
    357
    Glad to hear the issue is resolved :)
