Problem with incoming FAX
Discussion in '3CX Phone System - General' started by garrycarpenter, Feb 28, 2008.
  1. garrycarpenter
    Nov 28, 2007
    20
    I have been unable to get the incoming FAX working....
    I think I have now found out why (that or I am about to look very silly)
    We run with a 4 digit extension profile for the Fax is configured as default to 8888
    When I look in the logs, the FAX client is registering as 888
    This login info the client gets from the public_prstorage table in the 3CX database.
    All other entries for SIP ID's are updated correctly to the 4 digits except the FAX client....
    Bug?, looks like it to me..!!!
    I have tried editing the entry via an ODBC connection from Access but the record in not updateable....
    Anyone got any ideas?
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Can you please confirm the version and build number you are running?
  3. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    When you dial 8888 youself from a phone what do you hear?
    You can change the Fax Extensionnumbers. Maybe you have to change it in the general settings and then reboot.
  4. garrycarpenter
    Nov 28, 2007
    20
    Got the Fax service to show as 8888.... re-entered the fields submitted and rebooted...
    When I dail 8888 from an internal extension the call connects and drops almost stright away....
    Should I be able to hear anything?
  5. landfiets
    Jul 17, 2007
    243
    No thats fine. So try to fax from another faxmachine (maybe internally) to number 8888, what happens?
  6. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    666
    5
    I have the same problem in version 5.0. Likely to be a bug.
  7. garrycarpenter
    Nov 28, 2007
    20
    Have now upgraded to 5.1 4510...
    can now place a call to a FAX DID, call is answered but fax machine does not transmit (have tried 3 fax machines). I do get an email now to tell me a fax call did come in but it tells me "No Fax was received. Call was either not from a fax machine, or else fax handshaking failed."
    Anyone have any ideas?
  8. garrycarpenter
    Nov 28, 2007
    20
    I have 2 NIC's one 10.0.3.1 the other 10.1.1.8
    10.1.1.8 - 255.0.0.0 is for external extensions, VOIP Client and Admin GUI Access
    10.0.3.1 - 255.255.255.0 is for all other traffic (gateway (VOIP Hardware Phones, etc.)
    FAX is configures as in FAQ for our Patton 4960.(10.0.3.254 - 255.255.255.0)
    FAX entries have been added to 3CX PhoneSystem.ini as in FAQ
    [Fax]
    serverHost = 10.0.3.1
    And system has been restarted.
    Using wireshark I can see that all T38 traffic outbound from 3CX is still trying to use 10.1.1.8 to reach the Patton.
    All voice calls work in all directions.
    Server is Version5.1.4510.0.
  9. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,916
    225
    Please see this FAQ:
    http: //www.3cx.com/support/fax-multipleinterfaces/ - NO LONGER AVAILABLE. NEW LINK: http://www.3cx.com/pbx/voip-faq/
    Please check FAQs, many issues are documented in the FAQ section
  10. garrycarpenter
    Nov 28, 2007
    20
    AS I said.... I have followed and done that..........
