problem with Inphonex
Discussion in '3CX Phone System - General' started by erik, May 30, 2007.
  1. erik
    May 24, 2007
    6
    I've tried to connect to Inphonex provider ( http://www.inphonex.com ).
    I've set up the VoIP line at 3CX. At the first time the stutus appear as registered, but after the first outbound call the status changed to not registered. Calls go out via this provider and during the call colour of status changed to yellow, after ending of call status changes to red (not registered).
    Any suggestions ?
  2. giovanni0826
    Apr 6, 2007
    53
    what are your proxy settings?
  3. swarup.datta82
    Jul 18, 2007
    sip trunk?
    Hi, I just install asterisknow 1.4.0 - Beta 4 then I tried to make a call via inphonex, but the system just ask for the host, user and password!!! how can I make a hole config for that trunk? May I need to edit direct the config Files, sip.conf ?
  4. giovanni0826
    Apr 6, 2007
    53
    yes you do. Please realize the form is a different product.
  5. Anonymous
    Anonymous Guest
    Yep, it is a 3cx forum.
    I also believe that political and religion statements are not appreciated, please update your signature. If it was only to do me a favour.
    Thanks.
