problem with iphone
Discussion in 'iOS' started by rstory, Feb 23, 2012.
  1. rstory
    Jan 31, 2012
    sorry for my english
    Greetings.
    I am writing this time because I have the central point and confirguada perfectly with remote extensions without problem but when my iphone work perfect as local extention works, but when I'm remote or wifi or 3g I make calls simply by dialing the hang up immediately.
    Any help or guidance would appreciate the advance.
    thanks
    rstory
    10,754
    286
    I'm not positive, but it sounds like you are using the app as an extension off the 3CX PBX, correct?
    If so, then check the 3CX log (verbose mode shows more information). There may be some clues as to why the call is dropping, or if it is even reaching the PBX.
  3. rstory
    Jan 31, 2012
    Greetings. and thanks for your reply.
    I use the iphone as an extension 3cx pbx from being logged on the local network works fine make and receive calls like any other extension in when I'm connected outside the local network either by wifi or 3g only receive calls from 3cx but I can not make calls to other extensions or external calls.
    The second you have marked the number to call the school
    I have a laptop configured remotely 3CXPhone and works perfect.
    He explained that computer use:
    Grandstream GXW4104 and 3cx pbx server is installed on Windows Server 2003. and structured cabling with very good internet connection
    Below you send the server log.
    Code:
    10:11:31.000  [CM502001]: Source info: From: <sip:16@-------.dyndns.org:5060>;tag=oAZS6G7n5iOptTcuKleKAB8BTkv.4Gv4<sip:11@--------.dyndns.org:5060>
    10:11:31.000  [CM503013]: Call(3): Incoming call rejected, caller is unknown; msg=SipReq:  INVITE 11@--------.dyndns.org:5060 tid=PjhxLJYpMZir4fBJwsMbcb5O9eWlYDAxku
    cseq=INVITE contact=16@200.--.--.--:50708 / 21625 from(wire)
    10:11:30.453  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      INVITE sip:11@--------.dyndns.org:5060;transport=TCP SIP/2.0
      Via: SIP/2.0/TCP 200.-.--.--:50708;rport=50708;branch=z9hG4bKPjgOcsX09M8i-B4aKYtfI6ozY5yXkpk4.1
      Max-Forwards: 70
      Contact: <sip:16@200.-.--.--:50708;transport=tcp;ob>
      To: <sip:11@--------.dyndns.org:5060>
      From: <sip:16@------.dyndns.org:5060>;tag=oAZS6G7n5iOptTcuKleKAB8BTkv.4Gv4
      Call-ID: azJof52Jr6zS3FUTUcR5rb9LYxAJ5moy
      CSeq: 21624 INVITE
      Session-Expires: 1800
      Min-SE: 90
      Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
      Supported: replaces, 100rel, timer, norefersub
      User-Agent: 3CXPhone for iPhone 1.1.4
      Content-Length: 0
    10:11:30.453  [CM302001]: Authorization system can not identify source of: SipReq:  INVITE 11@------.dyndns.org:5060 tid=PjgOcsX09M8i-B4aKYtfI6ozY5yXkpk4.1 cseq=INVITE
    contact=16@200.-.--.--:50708 / 21624 from(wire)
    10:09:49.234  [CM503013]: Call(2): Incoming call rejected, caller is unknown; msg=SipReq:  INVITE 11@---------.dyndns.org:5060 tid=PjQyEeNiizr6KUm1SWYc-.L29RlIpImfRX
    cseq=INVITE contact=16@200.-.--.--:50708 / 30578 from(wire)
      Max-Forwards: 70
      Call-ID: KjiZ4WgWZGgZfCJd4dBszLvlJhw9nHGS
    10:08:30.781  [CM504001]: Ext.16: new contact is registered. Contact(s): [sip:16@200.-.--.--:50708;transport=tcp;ob/16]
    10:08:29.765  [CM504001]: Ext.16: new contact is registered. Contact(s): [sip:16@192.168.0.75:50707;transport=TCP;ob/16]
    10:02:25.640  [CM504001]: Ext.16: new contact is registered. Contact(s): [sip:16@192.168.0.75:62474;ob/16]
    10:00:50.187  New SIP device is on-line: MAC:--------; ip=192.168.0.75; contact=sip:192.168.0.75:5078
    09:45:28.718  [EC100007]: External application is connected:    application:servidor---:0/InterfaceWindows    local:127.0.0.1:5482    remote:127.0.0.1:1366
    09:08:09.750  [CM504001]: Ext.17: new contact is registered. Contact(s):
    [sip:17@127.0.0.1:64171;rinstance=81fbc477faa9d089/17,sip:17@127.0.0.1:64168;rinstance=6ea741630d0b4181/17,sip:17@127.0.0.1:64171;rinstance=eb01b2c3542b4c8d/17]
    08:59:01.109  Currently active calls - 1: [1]
    08:58:38.781  [CM503007]: Call(1): Device joined: sip:12@192.168.0.77:5060;transport=udp;user=phone
    08:58:38.765  [CM503002]: Call(1): Alerting sip:10000@192.168.0.78:5060;transport=udp
    08:58:35.343  [CM503004]: Call(1): Route 3: PSTNline:9795053@(Ln.10000@Pasarela)@
    [Dev:sip:10000@192.168.0.78:5060;transport=udp,Dev:sip:10001@192.168.0.78:5062;transport=udp,Dev:sip:10002@192.168.0.78:5064;transport=udp,Dev:sip:10003@192.168.0.78:5
    066;transport=udp]
    thanks for all the help I can provide
  4. leejor
    10,754
    286
    It looks like the call is being rejected because you are sending to a URL rather than the public IP of your router (that 3CX is behind). If you want to do that you have to put your DynDNS "name" into the Domain Name setting in 3CX.
  5. StefanW
    Jun 2, 2009
    1,216
    88
    leejor is right, if the IP you are coming from is not an IP the host is having it self (always the case in a NAT setting), we will match the domain name (settings advanced sip domain) with the one you have set at "External IP PBX" to be the same!
    If not the same = forbidden...
