Problem with ISDN Gateway
Discussion in '3CX Phone System - General' started by g.varakis, Jan 16, 2008.
  1. g.varakis
    Jan 16, 2008
    Hello everybody, this is my first post, although i have been using 3cx for more than 6 months now
    I am using Patton 4638 5port BRI Gateway with Linksys (921 & 961) IP SIP Phones
    My 3CX version is 5.0.3752.0
    I have setup the Patton gateway through the automated 3cx process and the saved configuration file, and all lines register fine
    When i use the standard configuration, the lines work correctly both in and out, but when i try to transfer a line from the SIP Phone that answered the call, the caller will not hear my on-hold music, but a busy-like tone instead (which i suspect comes from the Patton device). This only applies to calls with the PSTN, as internal hold/transfer plays the default wav file with no problem
    If i try to disable "Supports Re-Invite" on the gateway, then the caller can hear the wav, but once the transfer is complete, the caller is on silence, the calls are disconnected, and the call recipient sees the caller on hold.
    There is no error indication on the log files, just that the call ends as soon as the caller (isdn) and the recipient (sip) both join in SIP
    I will try to update to the newer version, as there seem to be some issues although from a test server that i set it up on, i experienced the same issues, without working too much on it tho.
  2. matictec
    matictec New Member
    Mar 31, 2008
    188
    have the same problem
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Is that correct? I think that the latest version of 3CX would likely solve your problems.
  4. matictec
    matictec New Member
    Mar 31, 2008
    188
    i have installed the newest version. i have the problem with a patton 4552 and 4554. if i disable "support re-invite" for the gateway then i can hear the music on hold from 3cx, else i hear an announcement from perhaps the telco or the patton itself. i dont know. the pattons use newest 5.3 firmware.
    i have also an installation with an patton 4638 and here we hear music on hold.
  5. matictec
    matictec New Member
    Mar 31, 2008
    188
    found the problem:
    it is an error that appears with patton templates for 5.X series when p2mp (MSN) is used.
    the error is that the patton enable the isdn feature "call-hold" for p2mp by default. i opened a ticket for this issue.
