Problem with Licence
Discussion in '3CX Phone System - General' started by manistopit, Nov 23, 2009.
  1. manistopit
    Feb 18, 2009
    26
    I'm using version 6 since last two years. After a gap of 8 months we again opened our office
    And when i try to enter my licence key of version 6 which brought few years back is not working and showing error
    "Licence key activation failed " error 62
    i do not wish to upgrade right now
    I also tried to do below operation but its showing error
    """Version 6.1 users who do not wish to upgrade to a more recent version, will have to patch the installation to the new version of the license installation module. To install the patch, this ZIP file (http://www.3cx.com/downloads/v6/php_cmstatus.zip) must be expanded, and the file contained within with filename “php_CMStatus.dll” must be copied over the older version inside the path “C:\Program Files\3CX PhoneSystem\Bin\Php\extensions”. After a restart of the machine, activation will be possible.""
    But its not working cause there is all ready “php_CMStatus.dll” file in my “C:\Program Files\3CX PhoneSystem\Bin\Php\extensions”
    and when i try to update its showing error
    ""The process cannot access the file because it is being used by another process "
    Kindly help
    Thank you in anticipation
  2. aveiser@veiser.de
    Dec 23, 2008
    23
    You should shutdown all 3CX services an then try again to copy the file.
  3. manistopit
    Feb 18, 2009
    26
    Thank you mate its all sorted out now
