Problem with local call over extensions, no audio
Discussion in '3CX Phone System - General' started by jensnb, Jun 21, 2008.
  1. jensnb
    Mar 11, 2008
    10
    my problem: I will make a local call from Extension 100 to 101 over outbound call! with local numbers. It goes out and in, but i have no audio.
    Here my log: Call 12 is out, Call 13 is in
    16:08:31.875 MediaServerReporting::RTPReceiver [MS105000] C:12.2: No RTP packets were received:remoteAddr=79.194.154.237:9002,extAddr=79.194.154.237:9000,localAddr=79.194.154.237:9000
    16:08:31.812 MediaServerReporting::RTPReceiver [MS105000] C:13.1: No RTP packets were received:remoteAddr=79.194.154.237:9000,extAddr=79.194.154.237:9002,localAddr=79.194.154.237:9002
    What can I do?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    You can do local calls if both ends are in local network.
    Or, you can try to setup your router to forward back outgoing packets addressed to your external IP.
  3. jensnb
    Mar 11, 2008
    10
    Hello Archie, thanks for your help,
    but I don`t understand this:
    "Or, you can try to setup your router to forward back outgoing packets addressed to your external IP"
    Sorry my english is bad, I come from German.
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    Sorry, no tech support in this forum. Read your router's manual. It should be in german, I believe.
    Your problem: your PC sends all packets it believes are external to default gateway. But it happens that destination IP - is public IP of your system. In that case your default gateway (router) should send them back to PC. Currently, it desn't.
