problem with Media Server - the server is stopping
Discussion in '3CX Phone System - General' started by hagesol, Apr 17, 2008.
  1. hagesol
    Mar 26, 2007
    22
    hi,,,
    I have a problem with 3cx Phonesystem Media Server. The Media Server is stopping, and I got an errormessage in windows. I start the Media Server into services.msc with the RUN-command, but it stop again. And the errormessage come up.
    Is it other people that have this problem with the new 3cx 5.1, or is it just me?
    Is it somebody out there that have a solution?
    I run MS Vista home premium 32-bit, with 3 gb RAM...
    Lars
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Windows error box specifies module that is really "crash".
    It may be related to DirectShow filters.
    If you provide more information we will be able to find the reasons.
    Logs of MediaServer (3CXMediaServe.log and 3CXMediaServer.trace.log) provides some additional information (I hope at least a piece of it)
  3. hagesol
    Mar 26, 2007
    22
    hi,,,
    thanks for your answare,,,
    her I send the files,,, hope you understand what is wrong,,,
    The error-message that come up is: "3cx PhoneSystem Application stop working, and is clossing. A problem do that the program stop working as it should. You get a message if a solutions are there"
    ps sorry for my english,,,
    Lars
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    Lars,
    Could you please specify information about
  5. hagesol
    Mar 26, 2007
    22
    I edit my post,,,
    but her is the message windows vista come up with: "3cx PhoneSystem Application stop working, and is clossing. A problem do that the program stop working as it should. You get a message if a solutions are there"
    Lars
  6. hagesol
    Mar 26, 2007
    22
    I have read the problemlogg in vista, and all it said is the: "3cx phonesystem application" have stop working,,, I don't find out what file it is the problem,,,
    any suggestion to where I could look?
    I tried the RUN-command: perfmon /rel
    Only thing that come up there was the file "3cxmediaserver.exe" has stop...
    lars
