Problem with music on hold.
et381
I've managed to setup 2 different VoIP providers through the PBX, both with incoming calls routed to the same extension.
However when I put somebody on hold, for 1 of the VoIP provider, music on hold is working. However for the other VoIP provider, music on hold is not working. Putting callers on hold and transfering calls between extensions seems to work for incoming calls through bouth VoIP provider.
What are some of the things I can do to troubleshoot and find out where the problem is?
Thanks.
Use supported VOIP providers :)
You can switch off 'PBX delivers audio' in 'other options' then it will be completely up to the VOIP provider. This assumes it can handle such functions, not all VOIP providers can do transfers, music on hold etc reliably.
Getting Started - Admin
YBow
Get 3CX - Absolutely Free!
3CX
