- Joined
- Apr 26, 2008
- Messages
- 12
- Reaction score
- 0
I have a problem with a new installation (v6.1.1793). After installing the software I configure extensions and the gateway and everything indicates OK. Once I do a reboot of the system I start getting the following errors and none of the extensions or the gateway register.
23:26:49.421 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=7d643c6290725c63 cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:26:49.421 printDetailedInfo [CM502001]: Source info: From: "Park line"[sip:*[email protected]:5060];tag=7458773b; To: "Park line"[sip:*[email protected]:5060]
23:26:49.421 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=7d643c6290725c63 cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire)
23:26:49.093 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=b10fcb11722ddc21 cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:26:49.093 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=694163314657d60c cseq=REGISTER [email protected]:40600 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:26:49.093 printDetailedInfo [CM502001]: Source info: From: "Unpark line"[sip:*[email protected]:5060];tag=cb3b6161; To: "Unpark line"[sip:*[email protected]:5060]
23:26:49.093 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=b10fcb11722ddc21 cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire)
23:26:49.093 printDetailedInfo [CM502001]: Source info: From: "Voice Mail Menu"[sip:[email protected]:5060];tag=a11a075f; To: "Voice Mail Menu"[sip:[email protected]:5060]
23:26:49.093 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=694163314657d60c cseq=REGISTER [email protected]:40600 / 2 from(wire)
23:26:48.984 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=bc6e1f745d2aa541 cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:26:48.984 printDetailedInfo [CM502001]: Source info: From: "Park line"[sip:*[email protected]:5060];tag=846b840f; To: "Park line"[sip:*[email protected]:5060]
23:26:48.984 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=bc6e1f745d2aa541 cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire)
23:26:48.656 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=fe373a062d36ea58 cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:26:48.656 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=e44956028b274c22 cseq=REGISTER [email protected]:40600 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:26:48.656 printDetailedInfo [CM502001]: Source info: From: "Unpark line"[sip:*[email protected]:5060];tag=f441002c; To: "Unpark line"[sip:*[email protected]:5060]
23:26:48.656 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=fe373a062d36ea58 cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire)
23:26:48.656 printDetailedInfo [CM502001]: Source info: From: "Voice Mail Menu"[sip:[email protected]:5060];tag=5528b663; To: "Voice Mail Menu"[sip:[email protected]:5060]
23:26:48.656 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=e44956028b274c22 cseq=REGISTER [email protected]:40600 / 2 from(wire)
23:26:48.546 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=7a09df221802344d cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:26:48.546 printDetailedInfo [CM502001]: Source info: From: "Park line"[sip:*[email protected]:5060];tag=33444877; To: "Park line"[sip:*[email protected]:5060]
23:26:48.546 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=7a09df221802344d cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire)
23:26:48.218 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=763bf954800b0467 cseq=REGISTER [email protected]:40600 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:26:48.218 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=d266a81c0027d30a cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:26:48.218 printDetailedInfo [CM502001]: Source info: From: "Voice Mail Menu"[sip:[email protected]:5060];tag=1555d42c; To: "Voice Mail Menu"[sip:[email protected]:5060]
23:26:48.218 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=763bf954800b0467 cseq=REGISTER [email protected]:40600 / 2 from(wire)
23:26:48.218 printDetailedInfo [CM502001]: Source info: From: "Unpark line"[sip:*[email protected]:5060];tag=e0375d51; To: "Unpark line"[sip:*[email protected]:5060]
23:26:48.218 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=d266a81c0027d30a cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire)
23:26:48.109 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=4b105a105907ba6f cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:26:48.109 printDetailedInfo [CM502001]: Source info: From: "Park line"[sip:*[email protected]:5060];tag=f357ad75; To: "Park line"[sip:*[email protected]:5060]
23:26:48.109 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=4b105a105907ba6f cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire)
23:26:47.781 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=b568f8461058722b cseq=REGISTER contact=*[email protected]:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
I have reinstalled the software several times and I always get the same error. Any ideas of what is going on???
Carlos Pinero
Carlos Pinero
