Problem with Nokia E70 answering from ringing group
Discussion in 'Windows' started by arpa, Apr 3, 2008.
  1. arpa
    Feb 14, 2008
    35
    I have problem with Nokia E70 , when a digital receptionist connects to a ringing group. When I try to answer from my Nokia, the phone reboots. I have no problem , when i call directly to the phone's extension, or when i call the ringing group where the specific extension belongs to.
    Any idea , or better, any solution...
  2. arpa
    Feb 14, 2008
    35
    I have uncheck the "Supports Re-Invite" option (Extension number/ Other options), and now seems to be ok.
