problem with Outbound Call Rules
Discussion in '3CX Phone System - General' started by gecomail, May 18, 2009.
  1. gecomail
    Apr 11, 2008
    14
    hi, i have this problem;
    if i define 2 rules with the same criteria,
    the first rule use his 3 gateway/provider for make the call,
    but if this 3 gateway/provider can't make the call (because all of this gateway are engaged from other user)
    the call is termimanted/closed.
    I think that the second rules (with the same criteria) must manages the call but no. :roll:
    Can anyone help me , please.
    sorry for my bad english.
    Buono Jury.
  2. sipero123
    Nov 24, 2008
    94
    Rules work from top to bottom and applies the first match.
    Normally I would advise having the second trunk under the first under the same rule. That way if the first one is not available it will use the second or third one setup.
    Jonathan Hamon
  3. gecomail
    Apr 11, 2008
    14
    sorry, but in my configuration the second rule not work.
    i have configured the system with this rules
    rule 1 , prefix criteria =03 -->gateway1,gateway2,gateway3
    rule 2 , prefix criteria =03 -->gateway4,gateway1,gateway2
    if gateway1,2,3 are engaged or busy, 3cx not use the rule2 and close the call.
  4. sipero123
    Nov 24, 2008
    94
    I suspect that it is meant to work that way. It will check through your rules and then apply the first one that is finds. It cannot then move onto another rule I suspect but maybe I'm wrong.
    Jonathan Hamon
  5. leejor
    11,095
    327
    I don't believe that there is the ability to move to another RULE if the first one fails. That is why there are other routes to use within one rule.
