- Joined
- May 24, 2007
- Messages
- 6
- Reaction score
- 0
I need to dial to PSTN line short dialing strings - 088 and 03.
If I make in Outbound call rule - Calls with number with 0 , without r,
dialing string 088 not go out, there is information - Call(C:35) is rejected: Destination could not be found. It seems that because extentions are 3-digits lengh the 3cx is searching extention number 088.
The dialing string 03 goes correctly to PSTN line.
If I make Calls with number with 0, with r ( remove the first digit 0), dialing string 0088 go out , but 003 doesn't go.
What to do ?
It will work if I make Calls with number with 00 then remove them (rr). But it's not convenient to dial 00 always when want to call to PSTN.
Could anybody give advice ?
What to do ?
