Problem with Outgoing Calls with local SIP provider
Discussion in '3CX Phone System - General' started by erling, Dec 21, 2011.
  1. erling
    Mar 26, 2010
    18
    I'm having problems setting up trunks with a local SIP Provider here in Austin, TX (DoubleHorn Communications)
    The trunks register, but will only accept incoming calls (no outgoing)
    Here's the log from 3CX when a call is attempted
    15:05:04.734 [CM503016]: Call(65): Attempt to reach <sip:1512XXXXXXX@10.20.126.40:5060> failed. Reason: Not Found
    15:05:04.734 [CM503003]: Call(65): Call to sip:1512XXXXXXX@69.94.224.2:5060 has failed; Cause: 404 Not Found; from IP:69.94.224.2:5060
    15:05:04.624 [CM503025]: Call(65): Calling VoIPline:1512XXXXXXX@(Ln.10008@DH Test)@[Dev:sip:5125014229@69.94.224.2:5060]
    15:05:04.562 [CM503004]: Call(65): Route 1: VoIPline:1512XXXXXXX@(Ln.10008@DH Test)@[Dev:sip:5125014229@69.94.224.2:5060]
    15:05:04.562 [CM503010]: Making route(s) to <sip:1512XXXXXXX@10.20.126.40:5060>
    15:05:04.562 [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.19920.0] PBX contact: [sip:10@127.0.0.1:5060]
    15:05:04.562 [CM503001]: Call(65): Incoming call from Ext.10 to <sip:1512XXXXXXX@10.20.126.40:5060>
    They have sent me a log from their end on how they see the invite
    INVITE sip:1512XXXXXXX@69.94.224.2:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.20.126.40:5060;branch=z9hG4bK-d8754z-d821b65ebf6f106f-1---d8754z-;rport
    Max-Forwards: 70
    Contact: <sip:5125014229@24.153.178.146:5060>
    To: <sip:1512XXXXXXX@69.94.224.2:5060>
    From: "Murray Messelt"<sip:5125014229@69.94.224.2:5060>;tag=71758d02
    Call-ID: MWQ5YTIwM2IzYTkxMWZiNGVmYjk5YzJhM2Q3YjhhM2Y.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Content-Type: application/sdp
    Supported: replaces
    User-Agent: 3CXPhoneSystem 10.0.22042.0
    Content-Length: 283
    Remote-Party-ID: "Murray Messelt"<sip:Murray%20Messelt@69.94.224.2:5060>;party=calling
    v=0
    o=3cxPS 317173268480 122859552769 IN IP4 24.153.178.146
    s=3cxPS Audio call
    c=IN IP4 24.153.178.146
    t=0 0
    m=audio 9004 RTP/AVP 0 8 3 101
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:3 GSM/8000
    a=rtpmap:101 telephone-event/8000
    a=sendrecv
    SIP/2.0 100 Trying
    CSeq: 1 INVITE
    Content-Length: 0
    SIP/2.0 404 Not Found
    To: <sip:1512XXXXXXX@69.94.224.2:5060>;tag=451f0e62
    CSeq: 1 INVITE
    Server: DHPS-P900 v1.3.4-005
    Content-Length: 0
    Any ideas?
    Thanks in advance,
    Murray
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Have you configured outgoing rule ?
    Regards
  3. erling
    Mar 26, 2010
    18
    Yes - just to pick that trunk when I call from a specific extension
  4. leejor
    10,362
    227
    What is their explanation as to why it isn't going through???
    This looks like they don't know what to do with the digits you are sending them.
