problem with outgoing calls
Discussion in '3CX Phone System - General' started by krishot, Jun 5, 2007.
  1. krishot
    Jun 5, 2007
    6
    I have problem with outgoing calls.I can make in-calls and calls between extensions but no out-calls.This is log of this problem.
    13:33:49.234 CallConf::Rejected Call(C:38) is rejected: Not acceptable here
    13:33:49.234 StratInOut::eek:nCancel Call(C:38): Call from Ext.100 to 800123456 terminated; reason: Not acceptable here
    13:33:48.406 CallConf::eek:nIncoming Call(C:38): Incoming call from Ext.100 to sip:0800123456@192.168.0.138
    Can u help me,please.
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hello
    How do you have outbound rules configured?
    How are you trying to dial out from ?
  3. NigelG
    Mar 29, 2007
    48
    Check that you have set up a valid outbound rule for the number you are calling.
    Regards
    NigelG
  4. krishot
    Jun 5, 2007
    6
    Thanks for your help.
    This is my setting of outbound rules
    Calls to Numbers starting with 0
    Calls from extension(s) 100-200
    Make outbound calls on
    VOIP Gateway
    VOIP Provide ipex
    Transform mask r
  5. exeicom
    May 25, 2007
    12
    try to remove r from transform mask.
    Exeicom
  6. Costas3CX
    Jan 23, 2007
    217
    hello,
    please allow me to disagree (no offence), r in transform mask is necessary to remove the 0 from the dialled number. you are trying to dial out with a provider? or gateway? is the line of the provider or gateway you are trying to call out from registered? also if it is registered, are outgoing calls allowed on that line? If they are allowed are you dialing the right number? I am not aware of your provider but some providers have different formats that they expect the number so you can make a call. Eg some of them need 0044 and some need 44 directly for the country code and maybe someone may need a + infront of the dialled number.
    So if you need more help, please give us more info. Which provider, which gateway etc.
  7. krishot
    Jun 5, 2007
    6
    1.I am trying to dial out with a provider.It is VOIPex (http://www.ipex.cz)
    2.Line is registred (green)
    3.I thing the calling number is correct.I tried it with eyeBeam.
    I suppose the problen is in domian (800123456@192.168.0.138)
    When i trid it with eyeBeam the number was 800123456@sip.ipex.cz
    I would appreciate any ideas.
    Thanks a lot Krishot
  8. dekatech
    Feb 13, 2007
    82
    The IP Phone used has a great deal how calls interact with 3CX, when a IP phone can be configured with a dial plan this can add some complexity for a general user setting the 3CX system up for the first time.
    using the IP 501 as an example the dial plan that comes configured in the US sets "0" as the operator regardless of whether the tranfsofm mask is used. If a user dials 0 the phone imedialtley dials the operator. This causes 3CX not to behave the way it should.
    In order ofr it to work properly, the user needs to change the dial plan on the IP 501 to use a digit other than 0 or change the 3CX system to use a number other than 0.
    For current issue....
    Do you have an account with a Voip Line provider? If not you will need one to make outbound calls.
    Do you have a firewall in place. If so you will need to configure it per manual.
    Let us know if you have any further issues.
    Travis
