Problem with Outlook and 3CX asst
Discussion in '3CX Phone System - General' started by jmatson, Dec 23, 2009.
  1. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    I am trying to use outlook to call a Number in the 813 area code. i'm in the 318 area code.
    but it's dialing some local number.
    Here are the logs
    15:48:59.265 [CM503008]: Call(244): Call is terminated
    15:47:45.493 [MS210001] C:244.3:Answer received. RTP connection[unsecure]: 10.1.10.33:16460(16461)
    15:47:45.492 Remote SDP is set for legC:244.3
    15:47:45.399 [CM503007]: Call(244): Device joined: sip:10000@10.1.10.16:5062
    15:47:45.396 [MS210002] C:244.3:Offer provided. Connection(transcoding mode): 74.93.147.249:7026(7027)
    15:47:45.392 [MS210001] C:244.4:Answer received. RTP connection[unsecure]: 10.1.10.16:16466(16467)
    15:47:45.390 Remote SDP is set for legC:244.4
    15:47:45.390 [CM505002]: Gateway:[ATT] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-3.3.6(GW)] PBX contact: [sip:10000@74.93.147.249:5060]
    15:47:45.388 [CM503002]: Call(244): Alerting sip:10000@10.1.10.16:5062
    15:47:45.309 [CM503025]: Call(244): Calling PSTNline:813775XXXX@(Ln.10000@ATT)@[Dev:sip:10000@10.1.10.16:5062]
    15:47:45.306 [MS210002] C:244.4:Offer provided. Connection(transcoding mode): 74.93.147.249:7028(7029)
    15:47:45.264 [CM503004]: Call(244): Route 2: VoIPline:813775XXXX@(Ln.10001@888Voip)@[Dev:sip:jessandbetty@cogentvoip.com:5060]
    15:47:45.264 [CM503004]: Call(244): Route 1: PSTNline:813775XXXX@(Ln.10000@ATT)@[Dev:sip:10000@10.1.10.16:5062]
    15:47:45.251 [CM503010]: Making route(s) to <sip:+1813775XXXX@127.0.0.1:5060>
    15:47:45.248 Refer: from="MakeCall"<sip:MakeCall@127.0.0.1:5060>;tag=e374427f; to="318891XXXX"<sip:100@127.0.0.1:5060>;tag=c35c472b; RefTo=<sip:+181377XXXX@127.0.0.1:5060>
    15:47:45.034 [MS210003] C:244.1:Answer provided. Connection(transcoding mode[unsecure]):127.0.0.1:7022(7023)
    15:47:45.033 [MS210001] C:244.3:Answer received. RTP connection[unsecure]: 10.1.10.33:16460(16461)
    15:47:45.031 Remote SDP is set for legC:244.3
  2. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    Problem Fixed. With Outbound rules
