Problem with process
Discussion in '3CX Phone System - General' started by Albert464, Jan 6, 2019.
  1. Albert464
    Oct 21, 2017
    26
    Every week I receive an email with this writing:
    3CX Service notification
    Following service (s) were stopped recently:
    3CXPhoneSystemMC01
    When I go to check I see that the process is over, can you help me to understand?
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,773
    278
    First thing is to make sure you are running Update 6. There were a number of bugs fixed that could cause that service to crash randomly.
    YiannisH_3CX likes this.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    Also update your installation to Debian 9 if you have not done so already as the system was designed to work with Debian 9.
  4. Albert464
    Oct 21, 2017
    26
    Thank you! How can I make this update?
    I have version 9.5, I installed the pbx with 3CX PBX Express
  5. YiannisH_3CX
    May 10, 2016
    7,783
    564
    You can see the exact build number on the Dashboard, under the Information column next to the licence version. For example 15.5.15502.6.
    If you are running a version older than 15.5.15502.6 then you can use the guide below to upgrade:
    https://www.3cx.com/blog/news/pbx-upgrade-update-6/
  6. Albert464
    Oct 21, 2017
    26
    I already use version 15.5.15502.6, But the service always stops.
  7. cobaltit
    Mar 22, 2012
    1,773
    278
    Are you using custom templates?
  8. Albert464
    Oct 21, 2017
    26
    I do not use any custom templates. I have a switchboard with a Yealink phone, but I do not use custom templates.
  9. cobaltit
    Mar 22, 2012
    1,773
    278
    What is the host? Physical machine, VM, etc?
  10. Albert464
    Oct 21, 2017
    26
    Amazon Lightsail
    512 MB Memory
    1 Core Processor
    20 GB SSD Disk
    1 TB Transfer
  11. cobaltit
    Mar 22, 2012
    1,773
    278
    Albert464 and YiannisH_3CX like this.
  12. YiannisH_3CX
    May 10, 2016
    7,783
    564
    As a first step i would also recommend adding more memory as shortage in memory could cause the service to stop.
    Albert464 likes this.
  13. Albert464
    Oct 21, 2017
    26
    Thank you very much, I upgraded, if it happens again I'll let you know. Thanks again.
  14. YiannisH_3CX
    May 10, 2016
    7,783
    564
    Please keep us updated with the results
