problem with two locations and one server
Discussion in '3CX Phone System - General' started by nedja, Nov 17, 2008.
  1. nedja
    Nov 16, 2008
    I have a next problem.
    I have a 3cx server installed on lan 1 and 2 IP phones( on the same LAN), and one Ip phone installed on lan 2. Both LANs have a IP static adresses. I can make a phone call from LAN1 to LAn 2, but it is not possible from LAN2 to LAN1.I got a on server status next following messages.
    16:49:35.875 Call::Terminate [CM503008]: Call(4): Call is terminated
    16:49:29.828 MediaServerReporting::STUN [MS101003] C:4.2: Possible firewall problem. Address mapping failed on STUN server 75.101.138.128:3478 for local address ":9000"
    16:49:29.375 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(4): Calling: Ext:Ext.163@[Dev:sip:163@192.168.1.106:5060]
    16:49:29.375 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:163@sip.mydomain.com]
    16:49:29.375 Extension::printEndpointInfo [CM505001]: Ext.161: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [C470IP020970000000] Transport: [sip:192.168.0.160:5060]
    16:49:29.375 CallCtrl::eek:nIncomingCall [CM503001]: Call(4): Incoming call from Ext.161 to [sip:163@sip.mydomain.com]
    how I can solve this problem?
    nedja
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    or try any other stun server
    stun.ekiga.net
    stun.ideasip.com
    stun01.sipphone.com
    stun.fwdnet.net
