problem with update 8.0.9941
Discussion in '3CX Phone System - General' started by cb, Nov 15, 2009.
  1. cb
    cb
    May 9, 2009
    8
    hello,
    i just installed my new version after having backuped my last one as usual and first, my settings for e164 section are lost and when i press the ok button from anywhere of the advanced section, systems tells me that the conference extension (70) is not valid so unable to validate my section e164 changes !!
    hope to have a solution soon....
    thank you
  2. dab
    dab
    Nov 1, 2009
    67
    Did you upgraded from 8.9908?
    Did you applied the backup-patch before you backup your 8.9908 settings?
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    If not re-do the settings manually again - it should not take you long. This was an oversight. The next version planned will have a backup checker to avoid bugs in a backup to be restored on a new version.
    SMTP server settings need to be configured
    Username and password
    If you had stun switched off you need to set it off manually
    Recordings path
  4. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    I just replaced a backup utility in 8.0.9941 to the patched version and restored old backup repeatedly.
  5. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Hi Igor
    On 9941 you do not need to replace the backup.
    The backup needs to be replaced on 9908. Then take backup and restore on 9941
    If you did not do this, you will need to add the settings in the advanced section manually. Let me know on this.
    Excuse us for the inconvenience caused. If you need any specific help to get things up and running let me know.
  6. cb
    cb
    May 9, 2009
    8
    hello,
    i actuallay upgraded from 8.9908 but i'm ok to change parameters if i could but as i told you i get an error message as what the conference extension is not valid so i can't modify my e164 settings
    thank you
  7. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    If your conference extension is not valid it means it is being used by another extension.
    What extension are you typing in? What extensions do you have setup?
  8. cb
    cb
    May 9, 2009
    8
    it's 70 by default i didn't change anything from the default settings and i tried to put 75 and it's the same error message
  9. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Try 700 maybe? or 7000 and see what happens.
  10. cb
    cb
    May 9, 2009
    8
    working fine with 700.... isn't it strange ?
    anyway thank you
  11. LeonidasG
    Nov 19, 2008
    1,557
    118
    It means that you are using a 3 Digit PBX.
    All of your numbers are something like: 100-101-102 right?
    Or are they 2 Digit? As in: 10-11-12?
  12. cb
    cb
    May 9, 2009
    8
    no, only on 2 digits but maybe it was lost in my last backup too ?
  13. Discovery Technology
    Apr 19, 2008
    278
    Hi guys,
    Any release notes available for 8.0.9941? I can't seem to locate any on the website at the moment.
    I am also assuming that the upgrade procedure from 8.0.9908 to 8.0.9941 is firstly you need to apply the patch, then perform a backup, then uninstall/reinstall?
  14. LeonidasG
    Nov 19, 2008
    1,557
    118
    Yep.
    If you have 9908 and you want to take a backup, you have to install the Patch first, the install to 9941 ( Which already includes these fixes )
    Apply the patch to 9908, then take a backup.
  15. cb
    cb
    May 9, 2009
    8
    yes but i'm already in the last version so i guess it's too late now...
  16. LeonidasG
    Nov 19, 2008
    1,557
    118
    if they arent too important you can still add them after the restore.
  17. igor.snezhko
    Jan 7, 2008
    668
    7
    I cannot make backup from 8.0.9532.468 I copied 3CXbackup.exe into BIN folder and now have backup error
    [​IMG]
    So I cannot upgrade to the new system.
